skimf
hi,
Recently i decided to attempt to build a go kart! I have no experience whatsoever using welders, angle grinders etc but everyone has to start somewhere!
so, i found a used honda gx160 kart engine on ebay, it had been tuned up by a company called UFO a couple of years ago and is said to make over 7hp. i got the engine, attached a fuel line, put oil in and it wouldn't start...
so, i changed the spark plug, i used an NGK one instead of one of these chinese copies and there is definitely a spark. The engine still didnt start, next i pulled off the carb and checked the main jet which was fine! still wouldnt start. so i put some cold start stuff in the air intake and it fired for a second before cutting out. i decided that the carb must be blocked somewhere i couldnt see so i soaked it in white spirit for a couple of hours. i put it back on and it fired up! however it would only run on full choke and was surging quite badly. So i soaked the carb again, same problem. its at this point i should say that all the gaskets are fine so i dont think there can be an air leak... so i bought some carb cleaner spray and sprayed some in the pilot jet because i read that might be blocked. it now runs fairly smoothly but still only on full choke??!! i have checked everywere for air leaks but cant find any!!! the engine does rev up nicely though as well. its really weird because it has no problems starting but still revs on the choke! As i have now resorted to desperate measures i thought it might be to do with the fact the air filter is missing the paper bit meaning that too much air is being sucked in that way, so i have now ordered a new genuine honda air filter! fun fun fun. Also, the fumes coming out the exhaust are quite clean if that helps! lastly i read that if you hold the throttle open and then open the choke it might run under heavy throttle, not happening, it just splutters and dies!!!!!!!!!!!!!!!! I have run it for a good 20 mins because i was told that it might not have been run for a while and need warming up before i could open the choke.
i have now cleaned the carb 4 times!
Thanks for any help and suggestions!
And just to say im definetly not muddling up the choke positions!
engine is causing no end of trouble!
