new member with a predator build
johnws6
im john from Alabama and im really glad to have gotten to join the forum. I work at a semi-famous hotrod shop called big oak garage. we make high end custom cars like these that can be seen on velocity channel fairly often.
so my boss comes up to me yesterday and says we are going to race gokarts and that I need one built in about 10 days. so yesterday I went out and got this
today I went out and got the 420 predator. I don't have any pictures of it but I pulled out the engine and the roll bar and ill have some more cut off soon. does anyone know a good thread or website to learn more about the engine and general gokarting for a new guy? im skilled enough will fab and mechanical but the basics of gokart culture is completely new to me
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Welcome!
I would have kept that 150cc engine. They can be made into AWESOME engines. So many more upgrades available for the 150cc engine and CVT system.
But it looks like you got a big industrial engine instead. That 420 will have lots of torque, but your rpms are still only going to be 3600 with the governor still intact. You will need to purchase a 40 series torque converter and do a lot of fab work...
Good luck and post results.
johnws6
thanks! I should have a lot of chassis fab done and I intend to rebuild the engine im going for 5500rpm since its just between guys at the shop. but with the deadline I have I wont be able to rebuild the engine yet
ALABAMA! Oh here we go again.:lolgoku:
So do you consider yourself a "Redneck" or just "Southern" :welcome2:
johnws6
I'm neither, I live in a culture I definitely don't belong around!
But as for the kart I cut the front and bent it at the pedals up 4.5 inches and welded it all back together other than the shock tower I didn't have time for. now I can lower it much more aggressively while also giving it more caster. I also used leftover double adjustable coilovers from a motorcycle I upgraded!
---------- Post added at 07:10 PM ---------- Previous post was at 07:04 PM ----------
Just get a intake and exhaust just for now since you are doing it in such a short time
the exhaust I can just mill a flange and weld up but do you have a recommendation on intake?
johnws6
I haven't gotten to touch the kart since I last updated but luckily no one else has either :thumbsup:
I did get my parts in. I guess im just going to machine the intake adapter myself when I make the exhaust but I did get some parts in
johnws6
got the shock tower welded up
machined an adapter for the new gear and welded it in place
and sat the motor in position just because I could :wai:
johnws6
I don't have any really good new pictures but it does run. and its loud enough for me to not want to drive at night even at stock levels. if anyone knows of a predator 420 engine build log let me know, my search hasn't been that productive for the 420 engine
---------- Post added at 10:44 PM ---------- Previous post was at 10:26 PM ----------
it does run and drive now, I haven't been great at documenting
https://youtu.be/Hs37mqcoUUg
burnout in car just because
https://youtu.be/GpxLgS95mX4
:iagree: Never, ever, ever, ever, ever, ever, ever weld anything to an axle!
Apart from the heat damage caused, what do you do if it's not aligned 100% or you need to remove the axle later?
johnws6
I never knew anyone was very professional about gokarts before now, no one around where I live has anything other than the Walmart karts for their kids. its a very interesting thing when you get to see the higher end side of things :thumbsup:
And I would normally agree but this isn't a kart I plan on making nice, actually I would want to get a race kart chassis now and sell this one. having a long history in machining welding and fab I can keep it aligned and since the original gear was welded on this massive axle I don't think welding another gear on will warp it too bad.
Lemme' 'splain Lucy....you are a stud where you live and work....and you are are a stud here too!! The difference is...with your cars...you're the man...
Here....you're just a stripped out stud....until we get the "nut" off ....you're just another PITA
Now...bad as that sounds....welcome to the forum! And the only point is....just because this is a gokart forum...don't cut us short!
johnws6
sorry if I came across the wrong way. im glad to see people as professional about karts as the guys here. its inspired me to build something that I can take pride in. my only point I was making is that before now I had never gotten to meet anyone passionate about karts, its a group of people who don't exist where I live. and for that matter the amount of people here who are passionate about any form of the combustion engine is in great shortage unfortunately. karting is just a culture ive never had a chance to be involved with up until now
It is a small culture. That is why we have to have a worldwide forum to keep 30 regular users. LOL. But thank you. I think you were complimenting us.
Welcome!!
johnws6
I was. any hobby is good if its done right, and with a sense of pride. seems like people around this site build some quality karts. I guess im going to have to work harder :thumbsup:
