Chain Link Sausage Link
mindymogul
Mistress of Destruction
Land of Camo and Fireball
So I just got my 30 Series T.C. from GoPowerSports (Unreal of difference in power) and put it on my Manco Magnum/Scorpion. Though for some reason it keeps snapping master links. In the probably 1200ft I rode it snapped 5 standard duty links and 3 heavy duty links at mid-high speeds. I've adjusted the position of the engine to make it tighter and looser but the same crap happens. Also the axle gear is in perfect alignment with the T.C. output gear. Ideas?
You could make sure you have the retainer clip in the correct direction. But better yet and what many here will tell you. Do not use a master link. But then you need a chain breaker.
Ummmmm...not really...totally doable with just a hammer, small socket, punch....(or uh cough cough "Poboy punch":(nail)....) and anvil: (again , something hard and flat)....done it many a time.....
mindymogul
You made no sense whatsoever....
A) A CHAIN REQUIRES A MASTER LINK!
B) It sounded like you were just jumbling words together you thought made sense
C) The Link is breaking during use... I know how to put chains together. I've probably done it more times than you've blinked.
The small piece of metal that holds the roller pins is literally breaking. Not the clip. The Chain roller link itself.
Both chancer & poboy are correct...
If you wish to use a master link, make sure the retainer clip is on the side of the chain farthest from the driven clutch; due to lack of clearance, the retainer clip will hit the driven every time...
A flat plate with a small (1/8") hole drilled in it, a pin punch & a hammer make a great makeshift chain breaker...
NO IT DOESN'T! THAT'S WHY THEY HAVE CHAIN BREAKERS...
Well, I do not use master link! THEY ARE NOT REQUIRED!
You have probably done it more than I have blinked because they break. Hence why I DO NOT use a master link.
I could explain the process to you, but I do not want to "jumble" any more words together for you.
Good Luck. Keep off the "Brain Lube" before you post, and remember YOU were the one looking for help.
Only one thing Mindy....regardless of where or how or why....if it keeps breaking AT THE MASTER LINK....then....that's the proverbial "WEAK" link....
As Tony pointed out...there is definitely a correct and incorrect way to install them...and where the link breaks is not in itself validation it was installed correctly....
Regardless, you CAN eliminate the master link...the only time you can't is when a half link is required....
I can assure you....Chancer was not "rambling" ....nor was I...but both speaking from experience.
KartFab
I put together a short video on the correct direction of the clip.
Also, as tony pointed out, you may have a clearance issue. Look for marks on the TAV2 backplate and edges of the driven unit and that will be a dead give away. You may need to space out the jackshaft sprocket a little more from the driven and backplate. Also, just to be thorough, double check for runout on the axle sprocket to make sure it is not wobbling. A straight edge would be nice to check the axle sprocket lineup with the jackshaft sprocket line up as well. Also, if you have excessive wear on the axle sprocket, deeper gouges, burrs, or sawtooth like teeth may be catching on the link. If you installed the engine slightly rotated, so the engine shaft is not at a perfect 90 degree angle to the axle sprocket, this may also cause it. Finally, if you installed a master link that is the wrong size, you may get this problem (e.g 40/41/420 pitches).
http://youtu.be/j1YJ8Hf-RIk
Good luck.
mindymogul
Well, I got another chain w/ is Grade 8 instead of Grade 5 so it can now pull 3400 ft lbs. Things seemed to be working out and I used a laserpoint system to align the axle and drive gears. Though after about 2 hours the chain actually broke altogether. So real question is it there too much strain somewhere in the T.C. when it's rolling or is it something to do with the chains?
You may have a clearance issue. Look for marks on the TAV2 backplate and edges of the driven unit and that will be a dead give away. You may need to space out the jackshaft sprocket a little more from the driven and backplate. Also, just to be thorough, double check for runout on the axle sprocket to make sure it is not wobbling. A straight edge would be nice to check the axle sprocket lineup with the jackshaft sprocket line up as well. Also, if you have excessive wear on the axle sprocket, deeper gouges, burrs, or sawtooth like teeth may be catching on the link. If you installed the engine slightly rotated, so the engine shaft is not at a perfect 90 degree angle to the axle sprocket, this may also cause it. Finally, if you installed a master link that is the wrong size, you may get this problem (e.g 40/41/420 pitches).
Good luck.
hmmm
Have you checked if the retaining clip is orientated in the correct direction. The closed part of the clip must be facing the direction of chain travel.
You haven't mentioned if you have done this, so I thought I would just mention it
You don't want to go there.
tazmannusa
Yettem, California
Pictures of the setup would help
What engine and what mods ?
What chain size ? #35,#40, or #41
What gear ratio and tire diameter ?
What sprockets # 35,40,41
It sounds like something may be miss matched or your getting to much flex in the mounts and or axle
I know, but sometimes people miss posts when they are scanning through the thread. Sometimes you also just have to say it in a different way for people to see what is being said :thumbsup:
Oh no! She saw what I posted and replied that "I was just jumbling words together" and apparently "she has correctly done this more times than I have blinked"
Clearly we have an expert Chain retainer clip installer in our midst. :bannana:
However when given sound advice from Kartfab about a list of other things to check, without responding to them, she came back and asked the same question. Of course after Installing yet another retainer. (grade 8 this time) OOOHHHH fancy..... But ..... wait for it..... oh! It broke too.:huh:
Whatever.... Some people just cannot be helped.:feedtroll:
