Tecumseh 4 hp no spark
Tgh567
Wilmington NC
I would try a new spark plug first. If that doesn't work come back and tell us and we'll try again to figure out the problem.
Tgh567
Wilmington NC
Ok I would put some gas in the spark plug hole and try again.
---------- Post added at 05:07 PM ---------- Previous post was at 05:06 PM ----------
Also I would try some starter fluid in the carb.
So if it works you are getting spark, or am i just misreading the above.
Uh huh....me too!!!! Tgh's advice is worthless if he has spark....but spot on if it just won't start....I R SO CONFUZED! Perhaps....he's confusing "engine firing "...ie: popping....with spark in the electrical system...."getting spark"....IDK....
New2Dis
Naperthrille, Illinois
I know that its not the spark plug since I replaced it with a new spark plug. And I know both of the spark plugs work (new and old) by testing them on another engine.
But....not necessarily doubting you....(but just to make sure we have the bases covered) ...how did you determine lack of spark?
Bear with us.....we will help you get this figured out!!!!
Ahaaa
almost completely pointless... but ahaaa :D
unscrew the plug,
rest it against the engine block (cable attached of course),
turn off the lights.. pull the string...
sparks or no sparks?
[EDIT]
Oh looking at the video.. make 100% sure that the kill switch (that dangly-bit) has no possibility to short against the engine block, and that includes foremost the open metal terminal you have it attached to (i.e. wrap in insulation tape)
still: test as above and let us know
Zombient
Junkyard Derelict
Waco, Texas
It's literally 1 or more of 6 things.
1. Bad spark plug.
2. Bad Coil.
3. Rust on flywheel/coil.
4. Wrong gap on coil/spark plug.
5. You're not pulling hard enough.
6. Grounding out the kill wire AKA kill switch is engaged.
New2Dis
I know its the spark because I did what sid said. I also made sure that the kill switch was correct.Ill be checking off Zombients list of wrongfullness tommorrow and I hope to get the mini bike up and running to have some drag races with the go kart.
correct, the best thing to do is to work your way back...
i.e.
spark plug
cable
coil
condenser(contacts) // if you have
magnet and flywheel
visually first (inspect and clean/fix what's obviously rusted, rotten or ripped)
then back and again en detail (multimeter and whatever tools you need to disassemble that thing)
but frankly... seeing that video again, that kill switch wiring is fishy.. or at least confusing me atm ;)
That's the wrong way around (at least to me it looks like it is)
unscrew that bolt and insulate the green wire to NOT short angainst the block, try again...
worst case it's the coil ground and it'll not spark...
best case it's the low oil ground (which in fact on my engine -non tecumseh- is green; my coil ground is black) and it'll fire right up.
So yeah, haven't payed much attention to that before, but it's at least worth a try that requires nothing but a screwdriver and some insulating tape ;)
