Lifan 15hp engine
Benjodie
I"ve been planning on building a go kart for a while and i want to start off first with a good motor. I made a thead yesturday about some engines I found online but I said to myself why not look local first. I came a across a lifan 15hp engine and its in good condition and runs. $140 he said and the throttle right now is done manually by hand just wondering if this engine can have a throttle cord attached to it?
Thanks
TLDR
Can a 15hp lifan engine have a throttle cord attched to it?
Zombient
Junkyard Derelict
Waco, Texas
I'm 99% sure they're like my 420cc, and from the pictures I'm looking at, you can hook a throttle up to it. I think they sell kits for them too...
Benjodie
its certianly an older model you think that should make a difference?
Edit- its 2008 i think I should look for something newer or is that fine? Someone has an un opened 8hp engine for $200, he bought the wrong engine and with return shipping hes better off selling it. Im thinking on buying that dont know brand yet.
that engine would be fine. No engines come with a remote throttle cable. The only problem with that engine is that you are going to need an expensive clutch to run it
Benjodie
It has a 1inch keyed shaft and how much do you think a clutch with torque converter cost?
