Comet 500 Series
Briggs8Stratton
Northbridge Massachusetts
Comet Duster Clutch
Hi everyone,
I have a Comet Duster clutch but I don't have a secondary/driven clutch to go with it. I need my secondary/driven clutch to be a 3/4 bore. Does anyone know if there is a secondary/driven clutch that will work with the Comet Duster that meets these specifications?
Briggs8Stratton
You know what I think that will work! Thanks very much! I searched the internet for hours, I'm surprised i didn't come across that. It says it needs a .92" top width belt, whereas the Comet Duster needs 1-1/4" to 1-3/16". Can I just use the slightly bigger belt on it? It won't really affect the performance much will it?
Briggs8Stratton
Mine is the 94 series. I can't find the driven unit for it anywhere. When I search only the primary drive unit comes up. How about using a 500 series with a 1" belt? Is that okay if the driver has 1-1/4"?
Just remember that you cannot just interchange drivers and drivens. Belts are also made to match certain distance specifications, so you might think that you are "close enough", but you will just be affecting the kart performance and burning through belts which can get expensive
tazmannusa
Yettem, California
With the 94c this is the one to use 3/4" bore they have it in 1" also
http://beltpalace.com/comet212299a.html
I think you could use a 780 series also
