Top end mph?
EC1
A claim of 35+ mph with a 5-10 hp 3600-4000rpm engine is found many times online (youtube...). What is the setup to reach these speeds while not violating a basic rule of thumb 1:5 drive ratio (and "reasonable...12in...?" Tires)? 1:5 is considered borderline abusive to clutches, so I understand.
Are speeds above 30mph for typical yard type karts fact or fiction? What are your experiences?
DHC
Fact... but the use of a TC is normally required. There are "other" methods but that's the only one I'm experienced w/... (I run a modded 6.5hp no governor, 5k RPM on 16" wheels geared to do 50mph... so stock rpm of 3600 for 35+ mph, isn't unreasonable...
crazykart
Crazy member
Swartz Creek, Michigan
can be fact or fiction. It depends on many factors, not just gear ratio and wheel size, but also total weight, engine hp, and driving surface, which combined will tell you if you can even run that high ratio, or maybe even higher.
All in all, 35 mph is doable, its when you see the claims like does 45-55-65 mph (on a stock engine, small tires, etc) that you have to laugh.
Zombient
Junkyard Derelict
Waco, Texas
15'' tires.
212 pred.
Modified exhaust/intake.
No Gov.
6-1 ratio using a Cent Clutch.
6'0 275lbs rider.
I got up to 39mph.
Joe-405
Enjoying New Projects
U.S.A.
From my last year's barstool build............
Gotta get the video to work but, gps speedo at 48mph with 3/4 throttle left. Rode it for awhile minus little tweaks here and there. It's all good..........
6.5 modded box stock project clone at about 5000rpm, tav2 knockoff and a 60 tooth rear sprocket. Engine will go a lot higher rpm. It needs proper alignment cause it got squirly quick at 45 plus.
And it's a wheelie machine also. Like will stand straight up from a roll !
http://www.diygokarts.com/vb/showpost.php?p=364700&postcount=1
10" tyres
5:1 gearing
centrifugal clutch
Modded GX160 engine including governor removal
Top speed is a trade off with acceleration; the suggested 5:1 or 6:1 gearing gives the best of both worlds; 5;1 on 12" tyres is about the limit before you start to damage a cent clutch, however, as suggested, with a TC, that story changes dramatically...
tazmannusa
Yettem, California
Fact
Trax 2 with 212 cc predator, stage 1 kit , Gov still intact , tav2 with 12 tooth, 85 tooth axle sprocket and 19" tires, tops out in the mid 30's at 4k rpm range
DHC
Yes it is from the factory but it is set with the adjusting screw , pull the screw out and it will gain some rpm
Im not gonna correct you on this... cause I really have NO idea what it is that your talking bout pulling to gain +400rpms... but to my knowledge there is nothing that can override the governor RPMs in that manner...
Im reminded of the boy that gained a whole HP 'just' by unscrewing the throttle limiter... (which is total malarkey).
PLZ give proof... Im alil curious aswell as afew others, Im sure.
:popcorn:
:popcorn:
No.. I'm afraid.. that's plausible by resetting the governor ...
4k is the max rpm a genuine Honda GX's governor can be set to;
and I guess (since I have no documentation to veri or falsify that)
that clones are capable of the same thing...
original Honda shop manual states this at least:
(3900 plus 100 margin...barely enough but enough;))
12->85 on 19" @4k rpm.. indeed 31.93 mph, the clutch will not like that.. but that's not the question right ;)
DHC
AHH... "that" would be, "...moving the governor arm."... not "pull the screw out and it will gain some rpm". But now I know...
Like I said... "Im not gonna correct you on this... cause I really have NO idea what it is that your talking bout pulling to gain +400rpms... but to my knowledge..." I wouldnt have ever replied if I knew 'that' was what he was talking bout... >.< (my bad)
I "have" wondered if that would work/be safe, but never saw any great advantage by doing it... but may good info to know w/ classes that run governors (if not already known/done).
tazmannusa
Yettem, California
Ok correct term Throttle lever limiting screw, pull it out and gain max rpm. The newer honda GX 390's Have a built in rev limiter in the coil 4000 rpm is the cut off point, not sure on the other honda models but they are probably the same. The predators do not so it is easy to gain 300 to 600 rpm maybe more depending on how strong the spring to Gov arm is
SID
did you calculate for the 10% overdrive from the tav 2 on the top speed there ?
