Engine Choice Help
MTopp
Professional Bear Handler
NJ
Hi all, I've been into go carts, minibikes, and atvs for a while. Had one a while back, but it got sold. Just got this one from my neighbor for a good price:
So my questions are:
It has this 6hp Tecumseh on it, I have ridden the cart a while ago when it ran, but now it won't run. I can get it started after a full carb cleaning I think. Are there any mods for this engine?
However, I was contemplating buying a Predator 212cc hf engine and modding it: remove governor, intake, exhaust, spark plug, billet flywheel, valve springs, etc.
Is that a good choice over the stock Tecumseh?
Also, would it be better if I bought the larger 301cc (8 hp) Predator engine and modded it less than the 212cc and used it instead for more power?
Maybe a Honda GX200?
So basically: 6hp Tecumseh vs 212cc Predator(w/alot of mods) vs 301cc Predator(w/ less mods) vs a Honda engine (gx200?)
Thanks,
Matt T.
Matt....212 Predator is the way to go....not as many cheap mods for the Tecumseh.
You can get about 10 hp out of that engine with mods....(don't know if /what mods are available for the 8hp.) Hondas are good, but pricey all the way around.
MTopp
NJ
Thanks for the input. I may try to get the Tecumseh running better and do a tune-up. Add a better air filter and exhaust.
I really want one with suspension or just save for an ATV
MTopp
NJ
Thing is I could get the 212cc and do all the mods and be $400 in. For that much I could get another higher horsepower engine? Any thoughts?
Well you said you were gonna sell it. So just make it run then. Otherwise go with the predator 212 for under 300 bucks including the engine cost you can easily get 10+ HP. If you pay the same 300 for a stock 10 or 12 hp engine, You will still want a better intake and exhaust and then you will have a 1" crankshaft and need a fancy expensive 1" clutch.
Pobay already stated your best bet get the Predator 212. Or like you said Just sell it and it wont matter.
MTopp
NJ
Oh yea, forgot about the shaft size. Thanks
MTopp
NJ
Well I'm gonna keep this cart for a lil while. Got the Tecumseh running pretty good. It had good acceleration, just not a high top speed, but I don't think I'd want to go any faster in this cart hahaha.
Ordered an air filter and carburetor rebuild kit from BMI carts online here.
