emudryj
If you already ordered a "kit"
YES, I did!!! great
It should come with new bearing hangars. They are really just GIANT washers. Here is what I would do, If I was doing what you are trying to do.
I would weld the new bearing hangars to the old bracket. Maybe even open up the old holes.
I thought about it but, I was concerned about the hanger misalignment being one of the causes of failure before, so I thought that starting from scratch should be better and I would not be double guessing latter.... the 2 hangers were coming with the kit anyways so better try to do it right once.
First put the bearing and shaft and hangars together. Then tack weld the hangars in place. This should help you get everything lined up straight and square. Be CAREFUL welding even tacking with the bearings in place. Then take it apart and securely weld the new hangars. Also since you are dealing with a jacked up bracket maybe add extra collars on each side of the bearing to keep everything in place.
This was exactly what I had in my mind... I'm not sure if is there any other better way to do it...
Also I thought about buying an extra set of hangers and place one on each out side, and 2 more on the inside. that way I could use 4 bearings.
Then I remembered I was not building a tank to go to war, and thought I was OVER doing it. Over doing things is good some times, but some other times is a disaster.
I doubt I could fit 2 bearings on each side and still have the right clearance for the sprockets...
In my opinion your Chicago welder should handle this job. If it is not working then stop before it looks like a bird pooped on it.
I found some great videos in youtube and I will practice on some old pieces of metal... By what I saw in those videos, it should be OK...
One out and one to go...
