22 horsepower Harbor Freight engine
anthonypeter
Hey everyone! So, I currently have a 1 seater yard cart with a 13 HP predator engine from Harbor Freight. I'm using a 40 series Comet torque converter which works great for transmitting the power to the wheels both on and off road. I'm looking into starting another build using the 22 horsepower engine from Harbor Freight on a much bigger frame. My question is, how do I get the power from the engine to the wheels (probably around 20" diameter, if that helps) safely? I've tried to find information on tractor clutches, hydrostatic transmissions, etc. etc. But I'm having no luck. The 40 series torque converter says it goes up to 18 horsepower, and I'm having trouble finding an off-road-oriented transmission/clutch set-up for more than 18 horsepower. ANY help would be greatly appreciated, thanks in advance!!!
AceEngineer
Albuquerque, NM
I think you will find that once you want more than what a 40 series Comet TC will handle, it becomes more cost effective to buy a used/wrecked motorcycle engine in the horsepower range you desire. It will come with its clutch and transmission attached. That way you get a clutch and transmission designed for the power level of the motor. Also, it is usually much simpler to integrate into a kart than a tractor or hydrostatic transmission.
AceEngineer
machinist@large
West Michigan, 49331
Another option is to run the Comet. Leaving the governor stock and in place would be mandatory. While definitely not recommended, we've had member's exceed the HP and torque spec's on the smaller series's in the past by about the same percentage with claims of no issues. Since I haven't done it myself, all I can do is pass on the claims made.....
AceEngineer
I agree with getting a bike engine. If you look at all the buggies around, you will see that they use bike or snowmobile engines
While I tend to agree with this statement, you will have to make sure that you gear low enough to make sure that you do not damage the TC. I cannot guarantee that it would work though
Johnnyboy
Massachusetts
from what I've read you could use a Comet 780 drive clutch (the model requiring a 1 3/16" belt is rated for up to 23hp) and mount a custom jackshaft for the driven. I have a similar idea myself...
