coil help
Chevyman1987
Tn
I got a older 5 hp Briggs and it has the points set up and I want to change it over to the plan coil set up but can't find the right coil ever one I got is wider so does anybody know one that would fit or part number
Zombient
Junkyard Derelict
Waco, Texas
What's the year of the engine?
I know just about 60's-90's 5hp Briggs are mostly interchangeable. I want to say it was mid 70's, early 80's when they stopped using points? It could be later.
Now, it does make a difference if the extra coils you have came off of a horizontal or vertical shaft engine. I know an 8hp coil won't fit a 5hp.
Chevyman1987
Tn
Ok no number any where that's what I'm having trouble with and it's bottom shaft 5 hp and the 2 other coils was off a 5 go but they where off a 90;s model and one off a 3 hp side shaft from 80's I'll get measurements in the am
Chevyman1987
Tn
It's 2 and 1/2 In wide and like rocketkart said it will work but he forgot to add it will also need zip ties to make it work as it should lol
That's why I asked, I have one....just can't remember if it's s good or not...but I can direct you where to get one if this one's bad....otherwise, you can have it for a warm flat beer and shipping...
Let me check it out....
Actually, first, I want to make sure this is what you're looking for, because they are actually about as common as pimples on a teenager....you just need to know where to look.
Chevyman1987
Tn
Yea that's what I'm lookin for
---------- Post added at 02:43 PM ---------- Previous post was at 02:42 PM ----------
And do you have a model number cause I'm needing 2 of them
Here's one: 10T802. 1253 BT. 09041754....
Now....here's the thing: that's the standard coil on a 3.5 B&S vertical shaft lawnmower engine, there's only a couple of million of them...so....that's why I wanted to know first....
Like I said...you just weren't looking in the right place.:thumbsup:
