BoostedBaja
I currently have a baja heat with a predator 212 engine. It is currently stock, but I plan on supercharging it with a belt driven smog pump I've found. I will use this thread for questions I have and for advice from you guys, as opposed to making several threads.
For anyone who has actually used a smog pump in this way, should I place the pump before or after the carburetor? I would like to keep away from pressurizing things ( placing the pump before the carb), but I am also worried about possible issues with fuel running through the pump, and causing damage( placing it after the carb). What do you guys think? Also, I am going to try to stay away from EFI, or anything else electric, if possible.
