Lefturns75
Guys I don't know if this has been posted before but I thought I might mention this in case others find the same problem. I had a box stock predator right out of the box give me some problems starting. It would start but struggle to idle and seemed to have no power. If I could keep it going long enough I would hear a loud click or even a clack if you will and it would come to life and run great. Being curious I opened the case and found that the compression release on the back side of the cam gear would stick causing the problem. I replaced it with a new cam I had extra and I have never had the problem again. Maybe this will help someone with this problem on the Chinese made* Predator. With my kind of luck, I will be the only one this ever happens too!
*edit
*edit
