Very slight mark nothing major.
That's enough...
I also have heavy duty springs also.
Well, that rules out the "valve bounce" theory but, as there is a mark on the piston, it
doesn't rule out contact; a piston moving at 6000rpm will create enough force to easily bend a 5'16" valve stem...
So is it good to upgrade valves while doing all of the other performance upgrades then?
As mentioned in
this thread,
any performance upgrade will
potentially shorten the life of an engine; I once heard about a $70k drag car engine that drove less than a mile before "expiring"...
The simple fact is, the more mods you do, the more mods you
need to do to keep up with what's already been done, ie: there's no point using harder valve springs on stock valves or a stock cam on an engine that revs to 7000rpm; eventually, something will touch something else &... well, you know the rest...
