Help removing torque converter driven unit
The Noose
Oklahoma City
It's an old Manco 2 seater. Really jerky at take off, tries to engage while idling, really slow top end speed.
Torque converter is in desperate need of some cleaning. Probably needs new springs. The driven part with the preloaded spring (I don't know what this is called) has several of those little rubber "buttons" missing. The problem is, I can't get it apart. I've taken off the retaining clip and the outside nut, but I was under the impression that once those were off, it should come apart fairly easy. Every youtube vidro ive seen, they just come right apart. This one won't move AT ALL. Am I missing a step? Is this thing threaded on somehow? Any help would be appreciated. Thanks.
The Noose
Oklahoma City
Anything guys? I'm stumped. I tried pulling it off with a gear puller and it didn't move. Are these things sometimes threaded?
2SlickNick
American Minibikes @ FB
Mesa, AZ.
1st off you normally don't take off retaining clip until you have the whole driven unit off the jackshaft.
I see you have the one nut off the JS at the driven unit. Make sure the other nut at the other end of JS is off too.
Your unit does look rusty, so get some pb blaster and spray on the threaded Js rod. The unit is not threaded on but is in place by keyway and key. You should be able to use a mallet or hammer and tap on the rod. Be careful to not mushroom the end. The rod should eventually slide out.
then once the unit is off you remove retaining clip, the cam, then spring, and then outer sheave to clean everything.
Half-breeder
"Edit" button removed
It 'should' literally, slide off... so what Ive done for my customer's TC's, that were stubborn to get off (that just dont 'sound right')...
As prescribed by Nick, soak the pee outta the shaft w/ 'PB blaster' (front/rear... use the straw attachment to spray into the keyway too). Give it awhile to do its duty (>.<)... if it seems to get caught up (stuck) in 1 particular area, you 'may' have a burr on the shaft (looks like the driven hub has been hit acouple times w/ a hammer... and the shaft appears to have atleast 1 whack I think I see). Ive run across the issue of burrs, just take a file to the areas that protrude (its doubtful youll take too much off).
If the shaft is bent (youll know cause the hub/unit/driven will wobble as rotated) it 'may' be easier to take off the entire jackshaft and slide it off the other way (had to do that acouple times)
Ofcourse... if you have access to a press, and can get the JShaft outta its housing... you can press the shaft off the unit, bent/rust/seized, or not...
The Noose
Oklahoma City
Thanks for the help. I think I am on the right track, but this sicker is just really, really frozen up tight.
So if I am understanding this correctly, I should be hitting(while being careful not to damage the threaded end) the jackshaft "inward" right? Also, why is it necessary to remove the nut that's on the opposite end of the jackshaft? Should the jackshaft be able to slide out of the housing if I've taken off the nut that goes in front of the driven unit?
I was using some other brand of anti seize spray cleaner stuff, but I went and got some of that pb blaster stuff. I've sprayed the threads down, so I'm going to let that sit over night and see if it helps. If that doesn't get it off, I am going to get a bigger puller tool and try that. Unless there is reason I shouldnt, that is...
---------- Post added at 08:55 PM ---------- Previous post was at 08:50 PM ----------
If using a bigger puller than the one I tried earlier doesn't do it, I might take it to my buddy's fab shop. I bet he has some kind of hydrolic press that could force it out. I was just worried maybe there was some other kind of retaining pin or something I wasn't seeing that had to be removed to get it off (yeah, that doesn't sound right), but from what I'm understanding from you guys, There isn't anything that "should" be preventing it from coming off.
Half-breeder
Correct... after the end nut is removed (on the driven side of the JShaft)... in theory... you can tip it on its side and everything should/can just all fall off the JShaft... tipping it the other way would then remove the actual shaft from the housing (which simply rides on a bearing/'retaining sleeve'... I think is what I can call em, a tube, between the end bearings, that prevents the bearings from being crushed in, as the whole unit is sandwiched together... Im sure someone will correct my 'dialect/lingo' if Im "wrong").
Im not too keen on using a 'puller' they can/have a tendency of bending the sheaves if its stuck on too badly... and I dont know anywhere that sells 'just' the sheaves! When removing the unit(s), force will always be directed as close to the shaft as possible, if not the shaft itself. To prevent damaging the threads... put the nut back on the threads, so the shaft is 'just- under' flush w/ the nut's top, and hit the nut... itll prevent the thread from most/any impact from the hammer.
Yea, PB blaster is one of a kind... if you use(d) WD-40, it makes a good bug killing, flame thrower... but not that good on eating away rust and seized items like PB does.
The only reason not to try a puller that I can think of is you might bust, bend, distort or destroy the clutch if not very careful. :thumbsup:
:feedtroll:
The Noose
Oklahoma City
:feedtroll:
Destroying the clutch is definitely something I want to avoid if possible.
---------- Post added at 10:06 PM ---------- Previous post was at 09:59 PM ----------
Cool. Sounds like this is just going to require a bit of patience, sweat, and liberal use of cleaning chemicals to get it apart. I will scrap the attempts at using the puller.
I really appreciate the advice and you taking the time to explain this to me. I'll let you guys know how it goes.
That is the most intelligent thing I've seen a new person say on here in quite a while! You're patience will be rewarded. If you have a propane torch you could try warming where the shaft goes through the clutch to help it along. Don't get it too hot though because aluminum does not glow or change colors before it gets runny! :smiley_omg:
:feedtroll:
Anything guys?
This is a 24 hour, international forum; by the time you started this thread, most members would've already signed off for the day so, bumping the thread 15 hours later will gain you no more response than waiting a full 24 hours...
In future, please wait at least 24 hours before bumping a thread/post...
Johnnyboy
Massachusetts
I had the same problem with mine. It just wouldn't budge at anything. First off, I'd remove the rear wheel if it inhibits your ability to use a mallet to tap out the jackshaft. This got me to where the end of the jackshaft was flush with the driven, but it still wouldn't come off. So, I took a wooden dowel and made a little punch for myself. That did the trick and shaft was pushed out of the driven. Also, as many others have mentioned, a healthy dose of wd-40 helps as well.
Wrong.....WD-40 doesn't help much....PB Blaster.
The Noose
Oklahoma City
Update: 3 days of trying everything I can think of and it hasn't budged. I'm thinking there has to be a burr or something holding it on. I've sprayed pb blaster in every possible place. I put the nut back on and beat on it with a hammer.
I've never seen a part stuck this tight on anything in my life. Frustrating. I've got the rest of the torque converter so clean you could eat off it. I've got a new green spring and a new set of buttons sitting here. Just completely getting my *** kicked by this **** driven unit.
Sorry to whine. Just needed to vent to people that understand how frustrating something like this can be. I'm going to work on it some more tomorrow and I'll let you know if I have any luck.
That sucks. Just continue with the PB blaster and hopefully it budges
Half-breeder
Take it down to your local mechanic and see if theyll press it off the shaft for ya...
The Noose
Oklahoma City
I think this might be the answer. I don't know how much they'll charge but at this point I have a solid 10 hours of work on my part trying to get it off, not to mention 30 dollars worth of penetrating lubricants, 4 trips to autozone, etc. I guess I'll just take the whole jackshaft housing off and take it to a mechanic somewhere.
The Noose
Oklahoma City
Well crap... I got impatient and tried a puller again. I got the outer piece off... because it broke in half. At some point someone beat directly on the driven and mushroomed the end where the retaining clip goes on. Hoping I can find that particular part without having to buy a completely new driven unit. If I do, oh well. I'm just glad to have gotten somewhere.
I'm still not out of the woods on this though. How do I get the inside half off? Is this part threaded on?
