Need help with motor
Chevyman1987
Tn
Ok so I got this PowerTrain PT 650E motor but can't find anything about it. So does any body know anything about these motors or where you can get parts
Hey....you're not texting your buddy here....5 or six posts and 2 threads under an hour isn't going to make any friends here.....
Please read the forum rules and show a little patience....
Chevyman1987
Tn
But they are about different things. I didn't think that would be wrong and it's only 3 post 2 about the motor and one about the karts
No ....it's 2 THREADS about the very same question....the other thread about the karts is a different subject and is fine....also....in that other thread you were multi-posting just far enough apart the software didn't catch it.....there's an edit button in the right hand corner that will allow you to add to the same post....
Chevyman1987
Tn
No the other post was about how unlock a motor. This one is to help find out what kind it is. But if I can find out how to del. a post I'll del. this one to keep it peaceful :)
My bad....you're fine....and you can't delete threads ....you can delete posts with the edit button....(which allows you to make fewer posts, too)....
EDIT: See this is one of several posts in one THREAD....while we're only talking about 3 threads total......reguardless of how many POSTS there are.....
Chevyman1987
Tn
Like I said I'm sorry if I do/did something wrong. Edit: are you talking about how many post in a days time way. If that's what your talking about I understand and won't do it again. Just let me know
No need to apologize....what I'm trying to say is that it's always better to keep things compact.....while they were different questions, they were about the same engine....and could/ should have been in the same thread....as far as multiple posting....using the edit button can reduce those....and you can post up to 10 pics in the same post....
I'm just trying to give you a heads up on what you really shouldn't be doing....we don't expect everyone to be perfect....but we do appreciate it when people try to do the right thing....
Your fine....:thumbsup:
I can't either....something ain't right....try to find some model/serial #'s besides that...
AH...HA!!!! Viola!!!! On a hunch....I added "generator" to "PowerTrain"....and found that that is the name of a Chinese generator....not the manufacturer of the engines used on them...so again....look for the series of numbers somewhere on that engine....
KartFab
It's made in China, is 6.5 hp, so you may want to Verify if it is a honda gx200 clone. Most clones have interchangeable exhausts, magneto, carb, etc. if it is a true clone, almost every part inside will also be interchangeable.
