Predator 212 string return
thisismyusername
Donut Eater
Predator 212 Billet Flywheel Replacement?
Ok so with removing the governor its recommended to replace the billet flywheel since the rpms will be a lot higher, but how likely is it to break without replacing? Or the question is kind of when will it brake after the governor is removed.
In short, with the stock valve springs in place, you will be ok...
The flywheel is usually the last piece to be upgraded, after the valve springs, which is after a billet conrod...
