2:1 Reduction Gearbox Clutch Removal
CoroTheCat
Builder
Denmark
Hello there!
I have a 2:1 reduction gearbox on my GX140 and I need to remove it, so that I can remove the governor. The only problem is that I cant get the clutch off. I tried to put some pressure on the clutch and hit the shaft with a rubber mallet, but that didn't move it the slightest bit. I really want to know if there is an easy way to get it off or if I just have to hit it harder. I don't want to damage it, so I didn't hit it very hard. I tried to remove it with a flywheel puller but the arms didn't fit behind the clutch so that didn't work.
I included some pictures of the clutch.
Thanks! :D
KartFab
I have some bad advice, but it may work.
1) spray some rust penetrant onto the output shaft (the usa has stuff called "PB Blaster Rust Buster".
2) install a bolt that will poke out of the crankshaft, screw it in as far as you can get it to go
3)hold/cup the gearbox with one hand, letting the engine dangle so the downward weight rests on the shaft and the shaft/bolt are pointed upward.
4) tap the bolt and see what happens. Hopefully it wont drop out onto the floor too fast.
Yes, pb blaster (or Caramba if you have access to that)
Anyway, there's a less violent idea I have.
The thing is (or I think it'll be) the center part [*6] will be stuck on your shaft.
You can (by carefully removing the four circlips[*11] and springs[*10] you can see) disassemble the clutch part from where you are.
Do that carefully and take notes of what goes where, to be sure you reinstall everything correctly. see that[*9] and [*7] are NOT identical although they look very much alike
After you removed the clutch plates, you can see they sat on a splined shaft center piece [*6].
That is mounted to your actual engine shaft with a 5mm key[*19]
and that's what you want to tap lightly with your rubber mallet to break free (with the help of a good penetrating oil!)
good luck
I also have some info. Have a look at the pic below for some parts views, and then THIS thread for a step by step on how to remove the reduction box
CoroTheCat
Builder
Denmark
I got the gearbox off! :D i Took one of the clutch plates off and sprayed the shaft with Wd-40 and after 10 minutes i was able to pull it off with a bit of force, and a screwdriver wedged behind the clutch. Thanks a lot for the help everyone! :D
CoroTheCat
Builder
Denmark
Does anyone know what kind of oil the reduction gearbox needs? Do I fill it with the same as the engine or something like transmission oil?
CoroTheCat
Builder
Denmark
Would it be okay to use fully synthetic 5w-40 oil in the engine, I have some of that laying around, or should I go out and buy something different?
Nothing less than SAE 10w30 is recommended.
Some engine manufacturers will void warranty if 5-10w40 is used.
What?
that doesn't sound right... not at all...
As far as I know as long as the recommended range (10W30 in your example)
is fully covered (which it is by 5W-40) the engine will be safe.
10W40, 5W30, and 5W50 all fully cover the recommended range of 10W30.
Well... at least that's common practice...
if you happen to know a manufacturer that indeed voids warranty if any wider range oil (fully covering rec. range) is used; please let me know which one...
[EDIT]
Correction:
10w40 can be used, but not 5w40.
See page 7 HERE.
still not plausible at all!!
and in case you wonder..
the newer manuals (like the current gx120 ,gx160, gx200)
list 5W-30 as well
HERE at page 8 for example...
and by incident.. it still fully covers 10W30!
CoroTheCat
Builder
Denmark
Well, I'm getting some mixed answers here guys... but thanks for the answers, well I just have to see what the majority of you recommend. :D :popcorn:
Russ2251
AZUSA:Powered by LAWN-BOY
See my correction.
Tecumseh for one...want another?
---------- Post added at 11:25 AM ---------- Previous post was at 11:24 AM ----------
See chart I posted...that's a genuine Honda manual...not me.
Well Russ.. that's an ancient manual you posted... I doubt 5W-30 oils were around back then...
see the NEWER manual (still original Honda... still GX120) manual I linked..
same chart, nearly the same page... 5W oil's listed!
And you cannot run a lower range oil without voiding the warranty...
wider range oils are okay.. ALWAYS!
that's all I'm saying.
See my correction.
Tecumseh for one...want another?.....
saw it... see mine :D
Tecumseh.. great, can you point me to the document stating that NO wider range oil can be used?
Or is that just it does not appear on the three bar chart and thus you think it's not covered by warranties?!
PS Coro.. 5W40 is okay, I'm sure ;)
