Where to buy *cheap* adjustable main jets?
Well, I don't know about you.. but MY Main jet sits on the end of my E-Tube in the center of my carb.
good luck reaching to that thumbscrew when it's installed.
Well you cannot install it.. since it won't fit.. likely because it's not a gx200 main jet at all!
In fact it's not a jet at all.. it's likely a Pilot screw replacement.
And, now the fun part: that is adjustable anyways!
So buy a full pilot screw and you're done
http://www.dlsmallplant.co.uk/pilot-screw-set-for-honda-gx200-16016-ze0-005/
(some can be broken off once set... and thus be unadjustable afterwards)
But frankly.. you payed 40 bucks for complete nonsense?
congrats, you have been scammed.
Adjustable main jets aren't that common from what I have seen. What you posted seems to be the going rate, in fact yours(link) is cheaper from the other one I saw a while ago at $45(I have no idea where I saw it).
Being a small precision made part, $40 is kinda a good deal.
mckutzy what you saw was likely an adjustable main jet for a mikuni carb (or whatever)..
well -again, not an adjustable jet per se, but a big jet with a restirction needle-
anyways
To make use of one of those,
you need to have OUTSIDE access to the e-tube in order to set it..
the stock gx carb can't provide that.
The only outside access you have is for the pilot jet (*headscratch*... at least from on top of my head ;))
and that's already settable with the pilot screw...
KartFab
So maybe it's just the bolt that holds the bowl on the carb and the needle goes into the existing jet to restrict fuel?
I dunno though
ForceFed86
Wichita KS
Whut U talk’n bout Willis?
Suppose I could word that a little more clearly. No one paid $40 for anything.
That is a link to a product that *looks* very similar to the Gx200 style adjustable main jet I ran years ago. I believe I paid 12$ for it back then, and it worked very well. I am asking if anyone knows where to find them for the clone carbs.
I had a “Jiang Dong” 6.5 china clone installed on a yard kart. I was able to reach around the motor and adjust the main jet orifice “on the fly” and monitor the tach to squeak the most RPM out of it. I wouldn’t be able to reach it on the kart I have now, but I could easily stop, get off the kart, adjust a hair and jump back on.
I dunno though
Thank You..
yes, that's indeed possible, a bowl screw with a restriction needle for the main jet...
Now another question arises... what size jet would need to be installed to have it roughly half way in and end up with the size we want on a daily basis?
So there's room in both directions to work with.
Does it come with a jet, or only the restrictor needle-thingy?
*shrugs*
ForceFed86
Wichita KS
It comes with a jet. And the needle valve assy. Has an o-ring on the shaft and screws in place of the bowl nut.
Here it is on a 390 carb. Stout racing sells them. Little pricey. I paid $13 shipped for my 390 china clone carb.
Here is exactly what min looked like.
http://www.2040-parts.com/honda-gx-...390-carburetors-adjustable-main-jet-i1058046/
machinist@large
West Michigan, 49331
The old flat head style Briggs & Stratton engine's had a similar main jet adjustment layout. It was one of the first things that went away when they had to start dealing with emissions regulations. It was a heck of a lot easier to use than fixed jet's.
And when I'm talking about old, I'm referring to the early to mid 1980's and before. :surrender: :oops:
ForceFed86
Wichita KS
Funny you mention that...
Back in my “Jiang Dong” kart days my buddy ran a flat head with the adjustable main. (that's where I got the idea).
He had a battery powered RC car servo on it with the control on the steering wheel. He kept it rich at low RPM for acceleration and leaned it out in the upper RPM. Pretty nifty setup!
