Clutch springs?
karter1998
New Hampshire
I plan on buying a Hilliard Extreme Duty Centrifugal Clutch for my mini bike with a 10 hp tecumseh. Wondering what springs i should buy? or should i just go with stock Springs. I have no idea what rpm my engine idles at but i like a low idle so it seems lower than normal. I heard somewhere that 1700 is around normal. That seems high but i am relatively new so i guess idk. I was unaware that adjustable springs were even a thing until recently. Just wondering if anybody had some better knowledge than me on the topic?
afremont
houston
If you have room to make it work, a torque converter might be more fun in the long run.
I would go with stock springs. You are not going to get your engine to idle lower than what it is meant to without it dying. why make things difficult for yourself.
A TC would be better if you can afford it. There are some cheaper 40 series knock offs that you can buy. Don't even look at the 30 series stuff with a engine your size
karter1998
New Hampshire
Well I planned on buying the clutch today. I only wanted to spend Like $50. The cheapest torque converter I found was a tav2 possibly a knock off for $110. The cheapest 40 series I saw was almost $400
Just remember that a 10HP engine will probably have a 1" output shaft. Centrifugal clutches for 1" shafts go for about $100
