Engine Shaft Mod?
Suzonda
Banned
Maine
I just got a Manco Scorpion that has a 6.5hp Craftsman engine.. I also bought a 3/4" Hilliard Extreme Duty clutch for it since the old one was slipping. Though when I drive about 600ft the new clutch starts to slip then becomes useless after 650ft. I have 2 other engines I can choose from. One is a 8hp Techumseh w/ a 1" shaft, the other is a Briggs 10hp 7/8" shaft but it's off a generator so it's elongated/tapered and non-slotted. If I were to machine or grind down the shaft on either one would it work out for me? Whole idea is to avoid buying a new clutch.
Your tires or too tall and weight of that kart is too much for a clutch. You need the Torque converter like nick said.
Suzonda
Banned
Maine
I know I need a TC but this is a 0% budget build for as much profit as I can get off from it. Everything on it was stuff that was laying around besides the factory parts. Though I also know that higher HP rating would allow the clutch to perform better. I'm just trying to get an opinion on which engine route I should take.
Well.....good luck with that....you've been told...changing engines isn't going to help....and may I say....I'm glad I won't be buying any karts from you any time soon....
We don't roll that way in Texas....and at least 90% of the members here would never scam someone with a faulty POS kart for money.....
Sorry....my two cents....
Russ2251
AZUSA:Powered by LAWN-BOY
It simply amazes me how some folks are naive enough to make a major change with total disregard as to why it was manufactured a certain way to begin with.
Any manufacturer will build their stuff as inexpensively as possible.
If Manco thought a centrifugal clutch would operate kart, they would have used one and saved million$.
It does not matter what engine (or output shaft) configuration is used. A stand alone centrifugal clutch will not operate that kart.
The slipping encountered is the result of some serious overloading and resultant overheating and could be compared to brake fade.
Bite the bullet and get the proper equipment. Eventually you will have to anyway.
Evoluent
Banned
N.H, USA
Interesting... that looks a LOT like the one that magically disappeared from my yard about a week ago. Even the right headrest is missing. Coincidence perhaps?
So did the clutch give you problems when you had it?
Evoluent
Banned
N.H, USA
No. In fact it had the factory setup on it. Only thing wrong with it was the tank was hit and had a gash in the bottom corner. I'm 260lb 6'3" and it hauled me 'till it ran out of fuel. So I don't know if "Suzonda" took off the factory piece or what, but I'm not a happy camper at the moment.
MadManAndrew
Fun-Club Chairman
I know it's really easy to say it couldn't be a coincidence, but these are pretty popular carts, yes? It just doesn't seem like somebody would drive across state lines to steal a go kart.
Suzonda
Banned
Maine
stfu. you have no idea what the **** ur talking about gf a horse or sumthin
afremont
houston
Wow, that wasn't very polite, was it? ;) My first IBTB post. Does this kind of thing happen a lot around here?
