kartnoob101
I have a fairly new predator 212 that is having some issues starting & staying running.
First off, starting it. I wasn't present for the initial startup (it was delivered when I was out of town and a friend started it up), but ever since the first time I've started it, the choke has been very finicky. I've used a few other small engines (snowblowers, generators) and the starting procedure has been pretty flawless: choke all the way on, pull 1-3 times, let it run for a few seconds, and slowly move the choke lever to off. On the predator, it's a 5+ minute chaos of trying every possible choke position while the engine sputters and dies after 1-5 seconds, hoping that it will stay running long enough to get the choke off. Today, while trying to restart the engine after it died (see below), I spent ~10 minutes with no success, just increasingly short sputters until I couldn't even get it to sputter anymore...
In the event that I do get it running, the fun doesn't stop there! It occasionally cuts out while idling, seemingly randomly. I think I know how to fix this (set idle higher by finding idle screw on the carb), but I've included this info in case it's related to the startup issue.
It has no modifications except disconnecting the yellow oil sensor cable.
I don't have much experience with engines so I'm asking here before trying any fixes by myself because I'm scared of harming the engine in my ignorance, but I think I should check the spark plug and perhaps the air/fuel mixture?
Any help is appreciated!
