Does a TC change recommended gearing?
doesgo
Minneapolis, Minnesota
I understand how to calculate gear ratios and how they affect a kart, but how does a torque converter play into the effective gearing? Also, would a Comet 40-series TC be a good choice for my setup?
My kart's specs:
550 lb with driver
13 hp Grayhound (Honda clone)
Live axle
17.5" diameter rear tires
54-tooth axle sprocket
Undecided jackshaft gear
A 40 series TC is the ONLY good choice for your setup. When you change from a centrifugal clutch to a TC, you can generally go slightly higher in gear ratio because of the variable transmission. Not a lot, but you can gear slightly higher
doesgo
Thanks, I'll go with the 40-series. I just saw the 44-series Magnum and wondered.
As for gearing, a 9t jackshaft gear would get me the magical 6:1 overall ratio, but would cap me at about 31 mph. Do you think with 13 hp and a TC it could handle something in the 5.4:1 range (10t) or is my rig just too heavy and my acceleration will be poor?
