Trailmaster goin slower
Bernie12
Hi all, I recently bought my son a MID XRS Trailmaster Go Kart. For the first few weeks it ran like a bat out of ****, however, now my son tells me that it is running slower. The engine is not missing or anything, so right now, I have no idea what's going on. Any thoughts?
Eric1204
Traverse City, MI
I had the same experience with my son. However, we got in it and checked the speed with an app on the phone and it wasn't any slower. For him it felt slower because he was used to the speed.
Now if it's actually slower - I got nothin for ya. Good luck.
Bernie12
Never mind, I removed the plastic cover that covers the clutch and torque converter and to my surprise, the clutch had almost fallen off. Seems when it left the business I purchased it from, no one bothered to make sure the bolt was tight! I tightened it up and my son took out for a spin and it is fine now. Doesn't anybody do their job anymore?
I am glad you got it sorted out
Bernie12
Yep, found that out. It came loose again and this time I put locktite on it and tightened the heck out of it. I hope this does it. Don't know where to go from here if it does it again.
Bernie12
Well, did it again. Now I am stumped. Don't know what to do next. Thinking maybe changing the lock washers out and see if that will help. Other than that, I don't know.
Bernie12
Used red locktite before, this time, I put the blue stuff on and replaced the lock washer. Hopefully this is it.
How are you tightening the bolt. I think usually you get it to a point and then the engine starts to just turn over. When I get to that point a put the wrench on the nut a whack it with a hammer handle or short piece of 2x4. The impact actually tightens it a little before the motor turns over. Same trick to get it off too.
minibiker
USA
I had that issue with my tav and I added an extra washer and I tighten the bolt with a impact drill
Red Loctite is stronger and meant to be more permanent than blue.....of course....if you have dirty, greasy threads and don't clean them, neither one is gonna do much....
