2 questions about Predator
verticalflight
I have a Predator engine mounted on a gokart. The engine is fairly new, maybe a 5-6 hours of runtime.
A few questions:
1) Sometimes, usually when colder, the engine will make a grinding noise for a few seconds. I think this happens if the idle falls too low. Someone mentioned that it is the clutch engaging/disengaging. Often if you don't have the brake on the kart will start moving forward. Does this mean that the idle should be set at a higher level? Or is another adjustment appropriate?
2) Over the weekend, I Noticed that the black shielding that wraps the throttle cable is getting bunched up at the place on the motor where the cable is mounted. What's the best thing to do? Strip the shielding? And then mount so that it has the right tension to keep it secure yet still movable?
Also someone mentioned on here that for karts you should remove the oil sensor. Does that really matter?
Thank you for the help in advance. Its our first kart so be patient!
Best,
Kris
Welcome to the forum!
You should lower your idle....it's too high....
A picture is worth a thousand words.....soooooo....post one up....(not hard....scroll down to 'Manage Attachments' .....
That being said: It sounds like your accelerator cable could indeed be binding....causing the high idle.....however , once again, you have it backwards....you probably need to move the cable in the clamp away from the carb and make it shorter.....not longer.....
EDIT: Oh yeah.....oil sensor....yes...disable it....it's for stationary applications....sooner or later....it'll die on you in turns....
verticalflight
Ok I will turn down the idle. Thanks...
But I need to strip the throttle cable as its getting bunched up anyway where that mount holds it to the motor (before it connect to the actual throttle pull on the motor). I'll post a pic as soon as I can.
Thank you!
thisismyusername
Donut Eater
Thank you!
I would just get a new brake cable. Make sure you don't get a really cheap one. Just go to a local bike shop and ask for a nice bmx bike cable. Make sure the outer coating outside the cable is secured on the throttle or brake handle(whichever your using as a throttle) and that it is secured on the engine. Then nothing should bunch up.
The grinding noise you hear could be a dry clutch bush, assuming you're using a centrifugal clutch; the bush needs to be lubricated every so often...
Also don't just disable the oil shut off switch. Reroute the wires to a button on your steering wheel. It makes a real convenient kill switch. Just get a momentary switch Like a horn switch or doorbell.
verticalflight
Just wanted to say thanks for all the input and advice.
I ended up replacing the throttle cable with a brake cable as suggested, it works great, although I am a bit slow on mechanical things and made it a little too short.
Also set the idle down a tad...
Thanks again
