Baja Warrior with Torque Coverter
Panhead5496
Athens, Georgia
Hey all! I just signed up on this website so I apologize if this is the wrong place to post this. I have a 2015 Baja warrior. I recently installed a torque converter. Here is the link to the one I used.
http://gokartsusa.com/Baja-Heat-MB200-Minibike-TC2-Torque-Converter.aspx
So I put the converter on and it went 9mph. After calling customer support I was told that it didn't make it go faster. Well that's what I wanted so I got online and found an easy way to remove the governor.
https://m.youtube.com/watch?v=gEpF3N-Z0RM
Now my bike flies. Almost 45 down hill! Oh and the rest of my bike is completelly stock.
The problem I'm having is my engine is getting quite warm. When I stop and idle I can feel heat coming from the engine. Is this normal? And I've noticed that there seems to be some vibration at low and high speeds. Again is this normal?
I really appreciate any and all opinions and advice. I am very new at the whole engine/mods/minibikes!
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Welcome!
Thank you for filling out your profile...
Engine heat is normal and so is vibration.
Bypassing the governor is a recipe for disaster. The plastic gov wheel is known for coming off at high rpms and ruining your engine. More rpms does equal more speed, but you are better off removing the entire gov internals.
You can achieve more top speed with gearing. 9 mph....? you must have hit or did something wrong....Adding the TC should have made a huge difference even with gov still attached.
Post some pics of your setup. might be able to help more.
Panhead5496
Athens, Georgia
So I'm guessing most people don't fill out their profile? I liked like that actually.
Ok so I noticed when I was taking pics that the bolt holding the silver thing to the crankshaft had come lose. I tightened it. I saw in the direction book that something was supposed to be tightened to 14 lbs? Is that tight? Also u can see in one pic I am pointing to the small gap in between the back plate and belt. Is this good or bad?
Next I removed the gov by pass cable. It went maybe 15 mph. In the same distance it went that fast I'm usually doing upper 20s with the gov by pass. Obviously that's slower than it was before the torques converter! I'm not wanting to do anything dangerous. So u r saying if I open up the engine and completely remove the governor gears that's a safe idea? And sorry I'm not sure of all the proper terms for the different parts. Appreciate your help!
Many places "online" say if you remove the governor. You need to buy different valve springs and a billet aluminum flywheel. THEY ARE WRONG. I guess they are trying to sell these parts. Most guys on this forum including me. Remove the governor completely. Yes remove all the extra linkage and crap then open up the crankcase and pull of the plastic gear. seal up any holes and put on a new gasket. Good to go. There are 3 or 4 How to posts at the DIYGK homepage. and probably a hundred on you tube. It is safe.
Panhead5496
Athens, Georgia
Please excuse my ignorance but why is it better to take the gov off in the engine? Isn't using the cable method the same thing or am I missing something? This is what I did on my bike.
The governor limits the engine revs to 3600, bypassing it you can turn like 5500, The plastic gear will break inside the motor. You don't want little solid pieces (and metal that holds the gear) bouncing around inside there. I was at first intimidated to pull the motor apart. But it was easy, when I did have a question/problem this forum helped me resolve it. Just do a little reading on this ol innerweb first.
KartFab
With the governor working fine and everything else in order, the mini bike goes 36 mph stock (w/torque converter).
Panhead5496
Athens, Georgia
Hey guys sorry to bump this thread from so long ago but I didn't want to make clutter with a new one. Anyway my question is does anyone know of tires I can put on my bike to make it a smoother ride on pavement? Thanks
KartFab
1) Take some air out of the ones you have
2) search on google for your tire size located on the sidewall of the tire. The less knobby, the smoother the ride. I've never had issues with riding mine on pavement being "rough rides" with 3 different types of knobby tires. This is an off road mini bike so most of the tires you are going to find are for off roading and traction.
