Probable clutch issues
Daver
Hi - Hi
I have a small go kart buggy - trail master mid xrx 165cc 6.5 hp with a cvt transmission. I'm getting less power than normal and can't go up most hills unless I have a lot of speed. The belt has a little bit of play but otherwise looks perfectly fine. At low Rpms everything seems fine. When I go higher on flat surface it seems ok. When I go higher from slow the belt doesn't engage and I get a lot of smoke and the engine gives out. I understand (I think) how the cvt works basically but haven't taken one apart yet.
Any suggestions for diagnostics?
firemanjim
Just kartin' around....
Houston Texas
:welcome2:
:useless:
Post a pic of what you got. Maybe we can see something obviously wrong, broke, or just messed up. Could be the belt.... Could be a spring...... ???
Daver
I posted a video on a website so you can see it in action. Looks like the driver isn't properly engaging? As you can see at idle the belt looks like it wants to move and it sounds "choppy". Once I put power to the engine the belt seems to start to move and drop down into the driven part but the driver part starts to smoke.
http://leorosner.com/video/
firemanjim
Houston Texas
Uhhhh YOUR clutch is COMING APART!!!!! DO NOT run it any more, until you fix it. You could cause SERIOUS bodily harm, or worse!!!
Your drive clutch needs a crap load of attention. The first thing I noticed is that it was wobbling, not spinning true. Then I could see a HUGE gap between the movable sheave and the outer cover.
Take it off. Take pics, every step of the way, or another video. Wrong length retainer bolt, will do what yours is doing.... BUT I need to see more. It could be the driven is just toast.....
Daver
Yea now that i watch again I see the gap you are talking about. I got the driver pulley off and everything actually looks ok. The springs came off pretty easy and they are anything but straight. Is that a no brainier to get new ones? If so any idea how I make sure I get the right ones for my clutch?
Now - on the crankshaft itself the brass piece rotates just fine and looks ok. BUT the piece that goes around the shaft and allows the clutch plate to move laterally on the shaft is stuck on the engine shaft. I hit it with nut blaster and wacked it gently a few times but it hasn't budged. Could this be part of the problem or just one problem? Any suggestions for liberating the piece (collar?) and I think the plate is a bit stuck on too.
Otherwise the driver pulley looks ok - could use some cleaning with brake cleaner to get rid of some light rust and wear. Once I get the piece off, clean everything, nrw springs, then reassemble I think I can see why the outer cover is wobbling.
firemanjim
Houston Texas
Well ,there is only one stock spring for the 30 series, but I think you can get a higher stall spring if you wanted to. I think you have the wrong length retaining bolt as well. It should not be able to separate like that. That could also very well be the cause of the wobbling I saw. The brass ring should rotate freely, its what let's the belt sit still at idle. The other sleeve, with the ribs on in, should slide back and forth. It sounds like the driver needs a ton of TLC. Post up some pics of what you have.
Look in the "FAQ" section on the forum. There is a thread about how to maintain your tc. Very informative.
Here we go
http://www.diygokarts.com/vb/showthread.php?t=7332
Daver
You guys have any suggestions for getting the hub (ridged piece) off the drive shaft? Not sure how it got stuck on there but I hit it with nut remover and I'm trying. To pull it off with a wrench to no avail. I guess I could try heating it next ?
Also - how do you prevent the drive shaft from turning while tightening the bolt that holds the driver unit on? I have a starter motor so I can't use the recoil rope....
PB blaster or something similar. Let it soak for a while
As for the engine turning, take out the spark plug, stick a cotton type rope (not nylon) down the hole (as much as you can), and this will stop the piston reaching the top and turning over. You can then just remove the rope when done
Daver
Hi - took a while to finally get driver off the shaft and then to clean the heck out of all the parts. I cleaned up all surfaces backs to near original polish and also replaced the springs with standard (blue) for a comet 30. I have a trail master mid xerox and I assume it's a comet or a comet knock off.
Reassembled everything and it idles fine and the wobbling must have just been the outer cover not being secured properly for whatever reason - it seems solid now.
HOWEVER there is now a noticeable loss of power. When I am sitting on the car the driver unit seems to engage and the cart jerks a bit but barely moves at all. When my 60 lb son gets on it rides ok and even up a hill - but with a lot less power and speed than before.
Any suggestions on how to diagnose? Bad driven unit or could I have messed up the install of the driver unit? Visual inspection of the assignment between driver and driven flat pullys looks good.
Thanks
Daver
Haven't touched the driven unit - only the driver so far. That seemed to be where the problem was so I started there.
I'm thinking I need to take off the driven unit, give it a good clean, and replace the spring on that unit as well. While i'm at it i'll get a new belt in case that's part of the problem.
Question - I'm trying to get the large nut off the driven unit and it rotates the chain/tires. Any suggestions for how to lock that down so I can break the initial seal of the bolt holding the driven unit on?
What you do is take out the spark plug, and then feed some cotton rope into the hole. You feed enough in so that when the engine turns over, the piston gets stuck. This will lock the engine in place for you to take the nut off. When you are done, pull the rope out and put the plug back in. Do not use nylon (plastic) rope, as pices of it could be left behind in the engine. I have used nylon before at a pinch, but it is not recommended
