5hp Briggs Flooding?
Orange Krate
North Texas
Well it’s floodin’ down in Texas, and I don’t just mean from the rain. Bullitt is STILL driving me crazy. After I blew up this engine While using this carburetor I’m still having problems! Now it’s flooding the carburetor BADLY, filling the cylinder and coming out the exhaust! I’m not certain that’s not what cratered the other engine because I remember hearing a “gurgling” noise while trying to start the old engine.
First time running this engine I noticed the same. I had to rich it to start then lean way back to keep it running. When I had gas come out the muffler I figured I was choking too much while too rich. After finally getting it to run right I parked it, knowing gas had gotten in the crankcase.
Needed it for a scene Saturday so I changed the oil and it cranked the night before and it ran fine with no flooding. Saturday morning same thing but after one take it died and gurgled. Carby full of gas!
I've cleaned it thoroghly and it does have a new diaphraghm. WTH is causing this!?
Edit: Have fun following all those links ;)
This is a Briggs diaphragm carb that bolts on top of the tank?????
:iagree:
I can't imagine how a tank top diaphragm carb can flood the engine while said engine is not pulsing the diaphragm to pump the fuel up... *shrugs*
The ONE thing i could imagine (I doubt it'd work though)
is if you installed the diaphragm in reverse, you might put the tank under pressure, thus it will push the gas up, rather than the carb is sucking it up...
but the solution would be simple:
loosen up the fuel cap, pressure will escape, carb wont flood.
And engine would die if running ;))
Again, I doubt you can build up enough pressure with a diaphragm pulsing in reverse to do so.. but I cannot come up with any other reason for a sitting engine like this to flood the carb
(well tipping it over... *gnah*)
:iagree:
Maybe he shouldn't have wrecked it! !!:rolleyes::lolgoku:
If you wanna make the trip Dennis....I'm sure I can fix it....no charge....
Orange Krate
North Texas
Different go-kart. Bullitt hasn't been wrecked...yet;)
May have to. Filming a scene at Burger's Lake anyway, just don't know when yet.
This dude having same problem but mine's not leaking out, just filling the carb plumb full.
http://youtu.be/CIKrLPG6di8
The cap is something to think about but it's happened with two different caps: one old one and a brand new one since it got made purdy.
Orange Krate
North Texas
Wait a pressurized tank makes sense! I just thought about it and remember bubbles coming up during said "gurgling" after the engine was off. I just assumed that was the sound of fuel running into the cylinder, it was vapor coming up through the flood after the bowl was siphoned(?) dry!
I will observe again this evening, take cap off etc. and update you all.
WOW!!!!! Haven't even thought about Burgers Lake in over 30 years!!!!
Only been there a few times.....the high dive platform is scary....
For the rest of the world: Burgers Lake is a small lake that's only used for swimming....it's surrounded by picnic tables...and it's a nice place for a family outing.....but basically a great big swimming pool with a natural bottom....
When nobody is in the water....(I have been told) ....the water is clear....full of swimmers.....you couldn't see your hand in front of your face.....
IIRC: The last time I was there....I didn't even bring shorts or a swimsuit....(some kind of picnic function that gathered there) .....so I spent most of my time playing foosball.....and they had everyone evacuate the lake that day...because a kid came up missing....I honestly can't remember for sure if they found him safe or he drowned.....but I'm pretty sure it was the later....
Not why I didn't go there again....just really didn't see the point in paying to swim in a lake....
let's hope for the best; if I'm actually right (I still cannot believe you can actually pressurize the tank enough with that diaphragm :eek:)
the test is simple (removing the tank cap when the engine is running should let it die rather quickly)
and the fix should be too.
Good Luck!
Orange Krate
North Texas
Ok, this beats all I ever saw!(on a small engine)
Runs fine with no cap. Just covering the tank kills it. Capping it makes gas well up in the carb even with it off and having been off for several minutes.
Checked and changed diaphragm just to be sure. No change. Weird!
http://youtu.be/0bFPF6UW9J0
That is interesting. How do you fix it? I am sure Brian or Jess would figure it out!
btw great book. I am almost done reading it
Harvey or Josie's dad! wait ..... no back to reality.....I bet Doug can fix it!
That is like some kind of weird vacuum/suction/siphon/manometer thing going on.
Yeah...maybe.....Dennis....take a small drill bit and drill a hole in the edge of the cap gasket....and then drill one in the cap....(like 1/16")....the gasket hole isn't critical....but it can't hurt...
Or just leave the cap off....:lolgoku:
before drilling holes...
look what I found...
so let me ask: is your machined tank top perfectly flat?
Orange Krate
North Texas
Sid, that's a different tank than mine. My diaphragm is on the side of the carb. There is only a gasket between carb and tank. But I will check the fuel pump cover plate for flatness.
A quick fix would be a vented cap but now it's a question of science!
The next morning, after leaving cap off all night, without starting the engine at all, I put the cap on and gas pumped up into the carburetor.
Either I've discovered perpetual motion or we've got a drinking bird here. Could the tank be sealed so tight and the gas boiling off at such a rate as to pressurize the tank thereby forcing gas up the tube into the carburetor?
I have switched to ethanol free gas (assuming ethanol might boil off faster idk) but I know there was still a little ethanol gas in there Saturday but we added more and the total level now is less than an inch.
Maybe the tank is supposed to vent itself into the carb an it has a blocked sinus cavity. I cleaned, and and blew through every orifice in there (even under the welch plugs) and they were all clear.
http://youtu.be/0n6dHdZpUUI
firemanjim
Just kartin' around....
Houston Texas
Swap out carb/tank for another one..... See what happens.... If you don't have another one, I believe I have the samecset up, sitting on a shelf in the garage. Clean tank, no rust... Black too.... :lolgoku:
I'll post a pic of it, if you're interested...... I might have a couple of them. I recall a couple more tanks and carbs in my storage... I'll have to see....
that's what I was afraid of Dennis :(
.. well then.. the issue might be still related;
so yes, check the pump cover as well as the carb body
for flatness;
BUT do not ignore the tank please.
It's still part of the pulsa jet system!
The gas is sucked up through the tube into the upper hole of the diaphragm part (upper flap), then goes out the lower hole and back into the tank;
where it fills either a small cavity first and a bigger well from there(
which basically is nothing but the fuel bowl as on an ordinary carb.)
or the well directly;
Oh One of those (can't recall which one comes with which carb) had only a very small opening for overflowing fuel to get back in the tank (casted machined tank top)
make sure that this opening isn't covered by accident;
otherwise it acts just like a non working float ;)
the other one is stamped steel and pretty much uncoverable ;)
Or in short: check your tank gasket too;
maybe it's not leaking, but closing the wrong hole instead ;)
