GY6 (150cc) engine rebuild
supermanotorious
Winchmaster 5000
New River, AZ
The shiny piston and cylinder (picture 2) is the new one that does not fit and is slightly larger than 62mm, I wanted to post both to show the difference
It's not just the thickness of the wall, the new piston is larger than the original.
Am I reading that thing wrong or does it look closer to 62 to me?
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Well, then that is the correct size for the qmj models.
All that means is a little bore cc 's for you. just wet sand the case to accept that sleeve.
supermanotorious
Winchmaster 5000
New River, AZ
I probably will since it was only $40 and had free shipping but will cost to send it back for a refund. If shipping was as low as $10 that would still be a 25% loss on my monies- not cool. If this is something a little elbow grease can fix then heck, isn't that why we're all here? Now if I sand it, does it need to fit snug or does the gasket take care of oil leakage?
2SlickNick
Mesa, AZ.
The gasket should take care out it.
Remember you will be sanding at the crankcase to accept the sleeve. Do you already have crank out or the case apart? don't leave any dust Nd crap in The case. Use a fine wet paper and do as even as possible all the way around.
