rebuilt carb now only run with choke
holyskittles
Haleyville, AL
hello again, i just got my carburetor rebuild kit today.went through it cleaned as best i could, and replaced everything that came in the kit. i put it back on and it only runs with choke on or about halfway on. its a briggs 18hp twin cylinder model#422437-1209. i don't know if it had this problem before because i could barely get it to run at all when i got it. i rebuilt it because when i filled the fuel tank up, and came back a few hours later the tank was empty and my oil was full of gas. i have a manual and i set it up exactly how it said to.Then adjusted the fuel mixture and the idle screw for about 15 min with no luck. the closest i can get it to run with the choke off is when i adjust the idle screw. the a/f mix screw doesn't seem to do much. any ideas?
firemanjim
Just kartin' around....
Houston Texas
Take it apart and clean it again. You missed something...... If your oil filled with fuel, sounds like the float was stuck. You need to make sure you poke through all the little holes....
Pics will help...
If it only runs with the choke on, something is not clean; can you rev it & open the choke? (ie: lift the throttle off idle & open the choke, will the engine continue to run?)
holyskittles
Haleyville, AL
I'll pull it apart again and check out when I get home and yes the engine does pretty much run when I open the throttle and disengage the choke but if I "romp" on it will spew a bit of fuel out of the top of the carb no matter what I do I can't disengage the choke all the way I checked for air leaks yesterday but I'll check again on a side note the fuel tank does sit about 2 ft above the engine idk if this engine is gravity fed or not I couldnt find it in the manual but there is what the manual calls a fuel pump build into the carburetor could this be the reason it's letting fuel get through it? Do you think moving it down level with the engine might help thanks everyone for all the advice so far and yes I did replace the diaphragm and all the spring and gaskets in the fuel pump
holyskittles
Haleyville, AL
update! so the more i thought about it the more it bothered me about the fuel tank sitting up there, so when i got home i disconnected it and ran the line into a gas can. i took a look inside the carb out of curiosity and the intake tubes were full of gas, all the way up to the bottom butterfly on the carb. so i pulled the spark plugs and turned it over a few times to clear it all out. then i changed the oil because it was full of fuel again. put it all back together and started it with the gas can on the ground. its pulling fuel up on its own so it does have a pump in it apparently. i opened the choke and just kept it running with the throttle. tried adjusting the fuel mixture with the screw to no avail. i did notice that when i would hit the throttle hard, it would throw fuel out of the top of the carb. could this be a valve adjustment problem? i also found a tiny hole on the top of the carb body where you would attach the breather that has vacuum on it if i plug it, it kills the engine no matter what i do i took some pics ill be uploading them in a minute to give ya'll a better grasp on what im talking about.
ok in the first pic the red is the hole i found that has vacuum on it the blue is the fule pump and the black is obviously the idle screw.
second pic is the fuel mixture screw circled in red
3rd and 4th pic are just for funsies
firemanjim
Houston Texas
Turn the air mix screw in all the way, but lightly so as not to damage the tip. Now using the notch as a reference, back the screw out about 1 & 1/2 turns. Try that as a starting point. 1/4 turn either way, to see what it does.....
holyskittles
Haleyville, AL
i tried that Mr fireman thats how the manual says to do it. it was a no go it is possible i tightened it to much last night as i was working in pretty much dark with it running ill pull it out and check it real quick
holyskittles
Haleyville, AL
checked it the tip looks fine to me only thing i know to do i take it back off and go through it all again would soaking it in gasoline be fine i have read that some carburetors have plastic and or rubber pieces in them that don't agree with some cleaning solvents
firemanjim
Houston Texas
We boil/soak them in lemon juice. Stinks like poo, but works great. Then you got to poke through all the little holes and blow through everything.
holyskittles
Haleyville, AL
boiling a carburetor in lemon juice. i thought i had heard it all lol ill give it a shot this thing has a copper float in it would you recommend replacing it with a plastic one i dont see anything wrong with it other than it feels like it would catch on things and its kinda heavy
Joe-405
Enjoying New Projects
U.S.A.
If it will idle with the choke on you can spray carb cleaner or starting fluid all over the carb. And if it fluctuates the idle any you have a air leak somewhere.
holyskittles
Haleyville, AL
that's a great idea joe idk why i didn't think about that i wouldn't say it idles tho more like runs balls to the wall lol i can adjust the choke and get it kinda close to an idle ill give it a shot before i pull the carb tomorrow i don't have an air filter or any of the parts that make up the air filter for this engine i guess i could put a piece of cardboard in front of it to keep over spray from getting sucked in updates tomorrow!
Plastic floats are probably heavier than brass.....shake that thing.....(the float) it may be leaking, which could be your problem.....
You can also sink it under water and check for bubbles....
Boiling in lemon juice is awesome....I recently revived a briggs carb that looked like it came off a shipwreck on the inside.....
You may want to plug the vacuum leak and reset your mixture screw before going to far. Also you will not get the mixture right until you get some type of working air cleaner on there. :stir:
:feedtroll:
holyskittles
Haleyville, AL
problem fixed. finally got around to pulling it back off. i took it apart and re-checked everything, spent some time exploring all the nooks and crannies, couldn't find anything wrong, so i gave it a good wash in carb cleaner and put it back together. threw it on there and now it runs like a dream. i obviously did some thing wrong the first time thanks for all the help guys!
You're welcome! !!! What did we do????,:lolgoku:
