Need help with backyard oval kart build
ThatGuy
A little lengthy, but wanted to be thorough as I could to get some legit answers.
So me and some friends are all building karts for a backyard oval race. No rules except a bone stock 212cc HF Predator enine must be used. Track will be both left and right turns, changing direction every other heat.
I've got a great headstart, just need help in the design department for what we are doing. The kart I've got is literally a winning oval dirt racing kart in the "run what you brung" class. It has 11" slicks, race bearings, 1 1/4 rear axle, Tomar racing clutch, etc. Got the kart in a trade about 9 months ago and now have something to use it for.
One thing that is killing me... the wheels/tires are too small for the terrain we are on. The kart has about 1.5" clearacne and I have calculated out 18" tires will be best for this. I would rather not have such a big tire, but it is what it is. I've found a few small ATVs on craigslist very cheap and want to buy one just for the wheels and tires. $100 for the whole ATV or $250 for just new wheels and tires.... yeah
I am a big guy and want to keep the 68t axle sprocket and replace the 12t clutch sprocket with a 10t to give me a final drive ratio of 6.8 with the 18" tires. Straights will be 150ft or so and want to have it as quick as possible. Have thought about getting a 40 torque convertor but in my research, it doesn't seem to help once up to speed. Am I wrong?
So I need your help with the setup. Would it be best to get 4 wide 18x9.5x8 tires and run all around or should I use the tires in front that will come with the ATV? I know I will need to buy hubs to make then work.
Kart is basically at a standstill until I get some answers. Been racking my brain about the right way to do it and am sure someone here can help. Already got the engine on, throttle hooked up, and ready for the race seat being mounted and fluids to be running around the neighborhood.
Thanks in advance for all the advice. If you can point out anything I'm missing or need, please speak up. I'm a newb at this stuff and need all the help I can get to gain an advantage.
firemanjim
Just kartin' around....
Houston Texas
If you can use a TC, then get one. You only need a 30 series..... And go with a maximum of 15" tall tires. Get a 56-58 tooth for the axle, and a 10 with the tc. 18" tires are just too big to be racing off road/dirt track, with a stock 212..... IMHO
ThatGuy
Thanks. Yeah, I'm not sold on the 18s but with how we are planning on the racing, more than likely will be ruts and groves that will need to be cleared.
I'm willing to buy a TC, but why would I want one if I get my gear ratio correct? The only time I can see it coming in handy is on the start, but dragging me down the rest of the race. I honestly just don't understand. I know how the TC works and all, I just don't see the advantage once up to speed.
firemanjim
Houston Texas
Uhh, cuz it throws you down to a real low gear to pull you out the whole, then shifts over to a 10% overdrive on the top end..... Having the tc will let you run a higher ratio than your buddies, giving you even more top end, while still having more low end than them with just a cc.....
EDIT
Run a sprocket/chain protector bolted to your sprocket......
jandj
Williamsburg, Va
How about you spend a little more time on track prep and smooth things out, unless there's some reason you can't.
How tight are the corners at your track?
Is it a conventional oval shape with high speed corners, or is it more of a 'paper-clip' shaped oval track with super tight corners you'd have to slow way down for?
ThatGuy
Track is going to be setup more like Talledega more than anything. Kind of a cross between a paperclip style and high speed corners. The corners are not banked and that is where my next delima with the tire width comes in.... tire width. Should I go wide all the way around or keep front tires a little skinnier?
ThatGuy
So another thought crossed my mind today.... what kind of torque convertor would be best for this setup? I'm thinking the 40 series because u do plan to swap the engine out in the future for more..... fun I guess you could say, but I wanted to know if that would take away from the kart's overall power by going to big..... Any thoughts?
