jgern
James gx390
Hey guys I have a kart which had a gx160 and swapped it out for a gx390 since I weigh 100kgs. I am running a dry clutch with 73tooth on the axle and 15tooth on the clutch. It has lots of torque which is great but not a lot of top end. I was wanting to know what would be the cheapest route of getting some high rpm's from this engine. I have already removed the governor and am getting around 4400rpm roughly from using the speed calculator.
If I get the arc conrod, change exhaust to header and get heavier valve springs will I make around 6500rpm? Or will I need an ARC flywheel also. Do the cams contribute to higher rpm's or just hp?
Thanks very much
James
Thanks very much
James
with no problems. Well, the only problem will be keeping the bugs out your mouth, because you can't stop laughin and gigglin......
Definitely bugs in your teeth grinning and laughin!
