Current build
SnowNemesis
The frame is stuffed with 1/2 inch rebar. The back end of the kart is very solid. I tested the frame by adding 600 lbs of random things sitting on it.. Did not flex a bit
SnowNemesis
All forums are the same. You always have the people who say what you do is wrong and stupid and what they do is always right. Why can't you guys just say good luck instead of cutting me down? I guess if the frame twist or falls apart at 80mph well..that's my problem
Desertduler
Take it from someone who has a sled engine powered kart built from scratch,be careful man and at least wear a helmet when you get this thing up and going and just post up some videos of your success.
rushking19
Richmond Virginia
Yeah listen to them I did the same as when I first wanted to build a go kart with a snowmobile engine, I was trying to put crazy amount of HP on a flimsy frame, but then I realized why they were saying it ,but go ahead and prove US all wrong, and they still think I'm crazy for putting my 24hp Rotax snowmobile engine on my manco 485 though, but it should hold up
Desertduler
Not only does the frame need to be strong enough,the front axle and spindles need to be strong enough to hold up to the added weight or one could wind up being pole vaulted and what I call fly swatted by the kart if the front end breaks and sticks in the ground when hauling a$$.
And just saying that the axle, will snap, or the sproket and that's a fact
I think so too....the good news is that this is likely to happen on take-off and and not top end....
Still....having half a sprocket buried in your back might ruin your whole day.....
But....despite what the OP may think....all forums are not the same....and we wish you well....but reading back through this thread....other than this post....I don't see where anyone said you were wrong......in fact...it reads to me as the other way around....
We only cautioned....you are the one saying we have no basis to do so....
Finally....most of us here know this...but apparently you don't....
You stated that the rear end was built with 1" square tube...(like that was some big improvement over the original frame) .....but round tube is actually more stable than square...(although only slightly) ....That statement alone gives me caution as to your ability to assess what is required to pull this off....
Secondly, stuffing re-bar in it is doing little more than making it heavier....angular bracing is what builds strength.....
Additionally....Desertdueler has brought up a very good point about a front end failure...although I like to think of it more in terms of catapult force....
Good luck....and where are all those pictures? :popcorn:
I think you all are meanies! :mad: It sounds like he knows what he is doing after all he added more steel. :lolgoku: Getting mouse trapped is fun, and the fun lasts a long time. I still have pain in my neck from when my motorcycle did it to me 38 years ago. :stir:
Please Take Pictures!
:feedtroll:
BirdFanatic
Jonesboro Arkansas
he has a death wish lol a sand rail made of 2 inch tubing all the way around has a 60hp engine its 4 stroke power band is a lot less and weighs 1000 pounds .Good luck you need life insurance
SnowNemesis
I guess its a good thing I have good life insurance. Lol. And yes I will take pictures of when I crash..
firemanjim
Just kartin' around....
Houston Texas
:funnypost::iagree:
Your sand rail is made with 1.625 " tubing, not 2"..... BUT you got the idea.....
