advice wanted on what I am missing
2ktj
St Louis, MO
Hello, this go kart is a first for me... so I have a few questions, and hopefully you guys can help me avoid making any mistakes. Apologies in advance if I am using the wrong terms.
So, long story short... I picked up a chassis from craigslist, it has everything but an engine. Grabbed a 212 predator and brought it home.
I do believe the only thing that I will need to get it going is a clutch and new chain... But since this is new to me, I'm probably not thinking of something.
This will be a "yard kart", not a level yard, but no real "grades", and it will be used by my young son eventually, (I'm not trying to make this a racer, just be able to scoot around the yard). The rear wheels are 7 inch with an outside tire diameter of about 13 inches. The "drive sprocket" attached to the rear wheel is a 54 tooth, with 1/2 inch peak to peak. I'm not looking for the fanciest stuff, just don't want to buy the wrong parts, or cheap junk.
So, will any clutch work? how many teeth should I look for (or should I change the "drive sprocket"), will I need to get other bits or pieces to assemble this engine to the kart? How far should the engine be from the drive sprocket? (mine looks like the end of the engine output shaft is even with the drive sprocket) Any advice or tips will be greatly appreciated.
Sorry for the long post, just hoping to only have to order parts once (My son is dying to go for a ride!). Thanks for the help!
Welcome.
Can you post a pic of your kart? As far as the teeth on the clutch and axle sprocket. for your needs (yard kart) you want a gear ratio of 6:1. Example 72tooth axle and 12tooth clutch=6:1 72divided by12. So 54/9 for you equals 6:1. Buuut....
There is a difference in the two. both are 6:1 but the acceleration and top speed will be different. 59/9 will spin the tires more on take off and 72/12 will get you a higher top speed. Look on the DIY homepage for a "speed Calculator" this will help too. Because not to confuse you with more but..... tire size comes into play as well.
2ktj
St Louis, MO
Welcome.
Thanks... and yeah, here are 2 pictures of the kart in question.
So if I were to go with the axle sprocket on it now, I just need to get a 9 tooth clutch? I'd be fine with a slower top speed, but I'm guessing for grass, maybe less low end may be the best solution.
As for the kart, The smaller front wheels may get changed out (not sure why that was done), and it does have an upper part that is removed for transport, but will be replaced once the paint is dry.
another thing you mentioned Chain. you said half inch between peaks. probably #40 chain. You need to know this to order the correct Clutch. and it sounds like you need the chain too. Check this out; for chain sizes. Also before you do anything on my advice alone I hope someone else chimes in here.
http://en.wikipedia.org/wiki/Roller_chain#Chain_strength
2ktj
St Louis, MO
Thanks for the advice, and don't worry about me doing anything on "your advice alone", I'm a (mostly) responsible adult, have been doing plenty of reading on this site and others, and know my way around a toolbox. I was just wondering if there was something I was missing, or if it should be set up a certain way. If it wasn't for this forum, there'd probably be a few wheels from harbor freight on it already haha, so if there was a clutch that was liked, or a specific thing that is needed to complete the kart, I'd rather ask first, instead of find out later (and have to wait for another order to ship!). Thanks again for the tips.
Thanks for the kind words. It's refreshing to have new members that not only do their homework, but allow us the opportunity and information necessary to allow us to help them.
Welcome to the forum!!!!
Feel free to go to the 'Off Topic' section and post up some pics of your dirt track builds....This forum is so about much more than just karts.....We love everything mechanical and pictures....
Yes thanks for actually looking through the forum and finding the simple answers. SOOOO many don't, that's why the disclaimer LOL. Sounds like your on the right track. Keep in touch as this progresses. Hope your son has a blast!
2ktj
St Louis, MO
Thanks, looks like my current axle sprocket is for a 41 chain, so that, along with a 10T clutch (didn't have any luck finding a 9T from a supplier or brand that came well regarded) is on the way. Since this cart will not be used on pavement or much at higher engine speeds, I'm guessing I'll be able to experience clutch buying again haha. (and then I'll know for sure about if I need a different size keyway, or set screws, etc...) I may play around with different gearing after I get a little seat time to see how this will be. There's still a few things I should do before I put the engine in, and am thinking about making it a little longer, but it shouldn't be too long before it's a runner.
P.K. No dirt track builds under my belt, but have plenty of desert racing photos (buggies, trophy trucks, you name it) from my time out west haha. Thanks for the welcome!
Umm, what? It doesn't matter whether the numbers are 59:9, 72:12 or 240:40, it's still 6:1 & will react exactly the same way; go & punch all 4 sets of numbers into the speed calc & you will see, the top speed won't change...
2ktj, a 10 tooth clutch should be fine with your setup; does the kart have a live or dead axle (can you spin each rear wheel independently)?
Ok that makes sense. 6:1 is 6:1. Top speed wont change. but is there a difference in take off speed or tire spin? I hope I have learned something so far. LOL
Looks like a dead axle, from pic 2
2ktj
St Louis, MO
It is a dead axle, Fabroman. As I keep reading more and more, there's plenty of bits that could be (and maybe should be) different. but I think I'll see how this goes, and then figure out what needs to change and what can stay. Clutch should be here this weekend, then I can get it together. Thanks again for the help!
Nope; as you said, 6:1 is 6:1...
See how it goes, if it seems a bit sluggish or your clutch heats up too much, you may need to change the axle sprocket for a larger one...
