kill switch help
kevbo22
Colorado
I have the predator 420cc. I removed the low oil sensor and plugged the hole with a bolt and thread lock. I noticed that when I try and turn the motor off now with the key switch, it wont turn off. But If I touch the yellow low oil sensor wire to the block it will die. How can I get this to turn off again when I turn the key to off position?
The yellow wire hanging down in the picture is the low oil sensor wire.
Not 100% sure on the 420. (electric start key switch?) but on my 212 predator. The "key" is just an on of switch. We leave it on all the time, and wired a doorbell, horn or any momentary switch to the low oil switch. It instantly kills the motor. Key is always on to pull start.
Some here have said this is wrong but it works the momentary switch on the low oil switch wire Will stop the motor completely at one push of a button.
kevbo22
Colorado
Ya its a electric start key switch. When the key gets turned to off, it should kill the engine. But thats not working anymore since I took the low oil sensor out.
Is it really all that a problem to have it turn off at the off position on the key, as opposed to just pressing a stop button?
I use the oil sensor relay as my kill on my bike and couldn't ask for a better way of shutdown than that.
kevbo22
Colorado
I was actually just looking at switches to do just that. I will probably just go that route. It will be easy and like you said will not be a big problem.
Ya, just rout inline a momentary on push button switch, from the gold coloured relay to a good ground. Put it in a good conveniently placed spot.
BTW I originally used the idea of a quick push button Kill switch when my daughter first got her Kart. I wanted to be sure she could quickly with out thinking or looking kill the engine. I think it is a good idea for any kart or driver. just hit a button rather than fumble with a switch or keys etc.
Here exactly what I have.
planejob
Retired Contract Operator
Wylie, TX USA (Dallas)
Are you guys saying that by wiring that momentary switch into the oil level sensor circuit you are having the ground "latch" in the off position so that the momentary switch does not have to be held down to kill the engine?
Yes. That oil sensor definitely kills the engine dead at one push. no need to hold it down.
