planejob
Retired Contract Operator
I look forward to showing this thing to you Poboy, it's been a learning experience. Also, I used to skydive out by you - it's not too far, we could get together.
So here's an update. I spent about 4 hours on Friday just "looking at it" and thinking about how I wanted it to end up. I'm not convinced this is the right seat for this cart, although it holds The Kid quite well.
Because I used a jackshaft, and mounted it solidly - not the best of ideas - I had to come up with a chain tensioner for the secondary. It's not glued on yet. I toyed with hinged arms, spring loaded hinged arms, spring loaded tensioners... I settled on this. It's a 3/16 non-swivel rod end with 6 inches of thread, I put a 3/16 bolt through it and will tension the chain by tightening a nut on the top. I considered putting a heavy spring, like a valve spring on top to provide some cushion for shock loads. What you see is a slot cut through a 1" square tube, I didn't cut all the way through at the bottom, and will brace it at the frame to keep the slot from opening up... We'll see how it goes.
I got new flux core welding wire. WOW. I was using Northern tool wire, and I didn't know any better. I switched to Lincoln wire and WOW. It doesn't look as bad as anymore. In this picture the horizontal weld was Lincoln wire and the vertical weld was Northen Tool wire.
Here's the steering arm setup I came up with. Everything is adjustable, toe is not set yet. Crossing the arms over each other allows for the inside wheel to turn more than the outside wheel. I spaced the pitman arms apart to keep the bolts and rod ends from interfering with each other as it turns.
The little hole you see was used for aligning the arms while welding. I drilled two holes in each arm so i can adjust the travel/effort a small amount.
A-C is mandatory. Cell phones I'll give you that.
I am an A-C repair guy so of course it is necessary and recommended to everyone all the time. Yeah 80* would be nice it was 90+ here the last 5 days lol
