"Go Kart Reverse Kit", What Is This Exactly?
l008com
So theres another thread about putting a reverse transmission on a Manco kart, which is something I've wanted to do since about the late 90s. So I did a little googling to see if I could find that comet gearbox any cheaper than $245.
Well, I didn't. But then I found this and I'm curious if it would work? I'm not really sure exactly how this even works.
http://www.bmikarts.com/Go-Kart-Reverse-Kit-with-Vertical-Mount-Handle_p_1031.html
I can't find any other photos of it, like other angles, or any details of how you install it. If it WAS a 'driven' torque converter pulley, that would be a pretty simple system. But looking at my driven pulley, I don't think there would be any room inside for any reversing mechanisms, so I don't think that's what this thing is.
It also says it's for 150cc cards and I think mine is a 170cc.
l008com
I dont' think it's the lever, it looks like the full kit to me. I don't know what a gy6 engine is though. But I assume that means it won't fit on the Dingo.
I really don't know....but here's my thinking on what I see and my limited knowledge.....
As Landuse has already pointed out....it doesn't work with engines that don't already have a reverse....(check the "works with most motors that have an external reverse ").....
Now....someone with more experience with TC's than me can verify this...but...I think the TC drivens won't t lock up when spun backwards....this has an external spring that engages the belt by moving the two sheaves together.....
