crazykart
Crazy member
So I've set off to build my first kart by myself. This is to document my build from start to finish, and for any help/guidance/whatever along the way. I will be hopefully getting into the actual fabrication by next weekend. So far I have all the materials to start the frame, and the engine I will be using. Price is always a very big point with me as I have a family to support on a minimal wage. It will be mainly on road, but here in Michigan our roads are crap, so it has to have a suspension. Originally I was thinking a swing arm in back, and dual a arms up front, but that was starting to get complicated, and I like to follow by KISS. Then it went to single a arms in front, which presented it's own problems. Now I'm thinking a modified trailing arms system on front. Seems like it would be simpler, easier, and I won't run into as many problems. I also want to keep it as light as possible, low, long 7', wide 3-4' (one bench seat to fit 2 people, well one adult and one child at a time) so no roll cage, but I will be putting a roll bar behind the seat just in case. I'm also going with a comet 30 series to make things easiest, good acceleration, and good speed. Listing of my materials: 7 7 foot by 1 1/2" square steel tunes, the guy told me they were 1/8 thick, but looks more like 14 gage or around there. 2 7 foot by 1/2 looks to be 16 gage square steel tubes, 4 1 1/4 inch by 2 to 2 1/2 foot round steel bars looks to be 16 gage, power washer Briggs intek 190 cc 5.5 hp motor. Misc 16 gage 1/2 inch square steel tubes from the power washer frame, engine mounting plate from the power washer frame.
Total cost so far $60, $45 for the 1 1/2" tubes, $15 for the power washer (bad pump), round pipe free (was part of our old garage door opener, 1/2 square tube free from work.
Yes I know the 1 1/2" is rusty, but I will use that to my advantage as I know a chemical that turns rust into a protective coating to stop further rusting, and seal the steel.
I will hopefully have the design done and uploaded the next few days, and if anyone wants to check it out just get Google sketchup and you can do so.
