HP or Gearing makes speed?
Ok so I know as much about go karts as a smart person can learn by hanging out on this forum the last 3 months. I am mechanical and have a varied background as a heat and A-C repair man, general DIY homeowner, and worked on Stock car racing for 6 or 8 years,15 years ago.
I see here on the forum that top speed is determined by gearing. and Gearing also regulates take off speed or tire spin. Most engines are governed to 3500 rpm and if you remove the gov. and do no other engine mod you can do about 5500rpm.
RPM+ gear ratio = speed.
So if a guy wanted his younger son to have a slower cart and bought him a 79cc predator and his older son a 212cc. Aren't both engines factory governed to 3500rpms and if they are geared the same both karts will be equally as fast. right?
So then how does putting a "stage 1" kit on a motor and increasing the H.P. neccesarily change anything. I know it does but how and why.
I hope this question spirs interesting conversation and knowledge.:idea2:
HP = RPM x torque << that's the difference...
A 79cc Predator produces 3.5 ft. lbs. of torque @ 2500 RPM
a 212cc Predator produces 8.1 ft-lbs. of torque @ 2500 RPM
If you had 2 identical karts driven by 2 identical drivers (as far as weight & ability), one kart fitted with a 79cc & the other fitted with a 212cc, they will eventually reach the same top speed (in theory) but the 79cc will take much longer to reach it because it has less than half the torque of the 212cc...
Likewise, if you had a third identical kart fitted with a 13hp engine, it would reach its top speed even faster than the other two, with the wheels spinning the whole time...
Torque = turning effort or, in simpler terms, the driving force of the engine; by doubling the torque, you halve the amount of acceleration time; to allow the smaller engined kart to accelerate the same as the 212cc powered kart, you would need to double the gearing (so, 12:1 instead of 6:1) which would halve the top speed...
WIth the governor intact, fitting any mods will increase low end torque; by simply fitting a hi-flow exhaust & air filter & rejetting the carb, that 8.1 ft-lbs. of torque quickly becomes 10-12 ft-lbs. of torque which, in turn, will increase acceleration...
Top speed is one thing, how fast you reach it is another thing entirely...
&#596; &#613; &#592; u &#596; &#477; &#633;
So if you drop your gear ratio from 6:1 to say 5:1 you will increase your top speed but you will need more horsepower to keep up with your old 6:1 take off speed.
Well, yes & no; in some cases, depending on other factors, lifting the gear ratio from 6:1 to 5:1 (low number = high gear, high number = low gear) may mean the engine can't reach its full potential & will "die out" before it reaches max RPM, meaning you won't reach the theoretical top speed...
This is all very interesting I guess it just depends on :what you want to do, where you usually ride.
