aaaaand I'm deaf
crankshaft
kart noob
Southern Oregon
Hey guys!
So I finally got my Harbor Freight Predator 420cc engine mounted on my go kart. (pics coming soon!!!) Aside from hacksawing off part of my frame, it was pretty easy :lolgoku:
Anyway, I slapped on an old exhaust header from a different build that I never used...
First start... f:censored:ing LOUD. Like :2guns::2guns::2guns: ....ears ringing for hours afterwards (just sitting at idle)
Here's a link to the ebay seller where I bought it: http://www.ebay.com/itm/Engine-Header-Exhaust-Pipe-for-Go-Kart-Predator-301cc-and-Predator-420cc-/271701535682?pt=LH_DefaultDomain_0&hash=item3f42ac6bc2
Gonna go buy some ear plugs now...
Sorry :useless:
justinlogue5_0
Can't leave it Stock!
Tn
What did you say?....What!?!?:roflol:
I am in the wrong business. I made two headers all most identical to that for around $4, LOL
Can't wait to see yours in action!:thumbsup:
BirdFanatic
Jonesboro Arkansas
Hey guys!
Sorry :useless:
there is prob nothing to slow the exhaust down (somthing inside to damper the exhaust or slow things down ) the exhaust i had on my mini cup had what looked like mesh inside
crankshaft
kart noob
Southern Oregon
I'm fairly certain there's no baffle in this pipe; it's just made to look like a muffler. Seems like solid construction; I just felt bad for my neighbors :oops:
It was cheaper when I bought it... I guess demand might have gone up since there's not a ton of places to buy headers specifically for the 420cc
BirdFanatic
Jonesboro Arkansas
(so basically you would be better off just using nothing because the muffler is doing nothing but making noise and looking good (for looks) A exhaust on a 4 stroke with just a little bit of restriction little is a lot better then no exhaust at all and better then a exhaust that restricts to much but the exhaust you have is not doing anything
crankshaft
kart noob
Southern Oregon
Yep. I'm probably going to put the stock air box back on for now. The header does look good though :thumbsup:
thebozz
Beaverton, Oregon
Is it correct that all engines need some restriction to function 100%
I was reading an artical a while back and it was talking about how you need to find the right exhaust tube diameter for your application. If you have a smaller diameter exhaust, it will create more backpressure but will create more velocity, velocity helps act kind of like a vacuum and actually helps pull even more exhaust out, but that benefit is counteracted with increased back pressure. So when someone puts a huge 4" exhaust on their prius :roflol:, they actually hurt performance. with a larger exhaust, the low end power suffers (if I'm not mistaken) but in the higher rpms, you typically put out higher numbers than stock (not always the case). So, in summary, you need to find the right balance for your engine and where you're looking to get your power. This is the reason top fuel dragsters and such all are open headers becuase they scream at WOT at all times so the backpressure buildup would be immense.
firemanjim
Just kartin' around....
Houston Texas
Not quite..... You need an exhaust pipe to help carry the heat away from the head, otherwise, you'll end up burning up a valve. Running nothing at all is NO good. Even a piece of tube 4" long is better than nothing.....
Justins exhaust sounds pretty good. He said he will post a sound clip of his $4 exhaust to compare to yours..... :)stir: Yes, I'm :stir: ing up a sound off...... :thumbsup::lolgoku:).......:lolgoku:
justinlogue5_0
Tn
I was wondering why my ears were burning....:roflol: I will try to post them, been having issues here lately with videos.
Axx3d
MN
Got some sparks shooting out of your clutch in the 2nd vid.. Chain rub?
justinlogue5_0
Tn
firemanjim
Houston Texas
I'll record mine again, tonight,when I get home. :wai:
Sounds/looks good ,Justin :thumbsup:
EDIT
Whoa! Sounds better in the second video!!
