Tecumseh OHH55 not starting after modifications
soggycrashed
Honolulu
I've been meaning to post this - this piece came out of the engine when I was working on it. I thought it was part of the governor mechanism (which I removed, nylon gear on the crankcase cover). Maybe I'm wrong and it is an integral part?
soggycrashed
Honolulu
I don't get it. The stock thermoplastic cam works fine, the Enduro .205 cam works fine, but the Dyno cam .255 race cam binds on the exhaust stroke. Size is identical, the lobes are just taller and rounded on the Dyno cam.
I've not seen one quite like that, but I DO believe that's a governor part.
Regarding the cam- what exactly is causing the bind? Is it too much lift, and the valve itself is striking the piston? Or something else?
soggycrashed
Honolulu
I have no idea. I don't see anything hitting. The issue is that this doesn't happen with the sidecover off - once I put the sidecover on it starts to bind on the exhaust stroke. When the sidecover goes on I think it raises the cam up a little bit, that is all. I'm going to try to raise the cam a bit with my finger, turn the flywheel, and shine a flashlight in to see what's going on.
Try that. Also try loosening the cylinder head bolts. If the valve is interfering, that oughta tell you. Popping the rockers off would help indicate the same.
soggycrashed
Honolulu
The rockers aren't on right now, I'm just watching the pushrods move up and down.
I made a video w/ the .255 and the sidecover on/off, and one with the Enduro cam. FYI any grinding noises when I rotate the flywheel are from it hitting the metal shroud at the bottom of the engine.
With/without sidecover, you can hear the clunk on the exhaust stroke. It gets stuck a few times:
https://www.youtube.com/watch?v=eotNvCTEB6A&feature=youtu.be
With Enduro cam:
https://www.youtube.com/watch?v=q3gqRDGNLtk&feature=youtu.be
soggycrashed
Honolulu
I got impatient and installed the Enduro cam. Revs to about 2k. Adjustment of the jet doesn't do much to improve it, and after 1 minute of it running the muffler was smoking.
Edit: Smoke might have been the muffler burning off oil that I didn't wipe off.
Edit 2: No more muffler smoke, it was oil. The engine idles but won't rev past 2k before bogging down. Adjustment of the jet and fuel/air mixture doesn't do much.
I wouldn't necessarily suspect it to be "bad" either, but maybe just too much lift? Even if it WAS bad, that might be a bear to detect without some very accurate measuring equipment.
soggycrashed
Honolulu
I have no idea. This cam is specifically designed for a 5.5 OHV Tecumseh. I'm hoping Xtreme Yard Karts might reply as he's building a 6hp Tecumseh OHV with this same cam.
Xtreme Yard Karts
Sweet Home Alabama!
Sorry, I haven't been on here in the last few days. I don't know what it could be, unless the cam is badly bent, which I can't imagine that being the case.
I will put my 255 cam in my engine tomorrow and spin it over just to check to see what it does. Like I said, I used to run the cams with no issues, so I don't what's going on with them.
