Riderforlife
Hey everyone. I bought a header, main jet, emulsion tube, and air filter.
http://www.ombwarehouse.com/Racing-Jet-Kit.html
http://www.ombwarehouse.com/GX200-Clone-Air-Filter-Kit.html
http://www.ombwarehouse.com/Weiner-Pipe.html
I put all of it on and there is a problem. The gas from the carb flows out though the adapter and into the air filter! On the stock air filter with the whole mechanism, it didn't leak, but now it does! I have no idea why this is happened, and help would be appreciated! Thanks
Also, I have a fuel pump on the top of the engine...
http://www.princessauto.com/en/detail/6-5-hp-196cc-ohv-gas-engine/A-p8088379e
This pump flows into the carb, and then into the OHV container. The only thing is, with the new air filter, there is nowhere to put this tube! So where do I put it, and what do i put into the OHV hole?
thank you!
thank you!
What he said, PLUS--Take the hose coming off your "OHV Container" and just simply put a zip tie on it to let it hang in a down position( make sure you do not crimp the hose shut) and leave it alone. This should solve your issues and get you back ridding.
