New Go-Kart
NapalmicAcid
I picked up a new Go-Kart from a guy on Craigslist for $80. It had a Briggs and Straton that needed a new carb so i put it aside and plan on putting a predator on. It has a odd setup on the one wheel drive system see picture, everything oddly attached.
One question for right now
The guy may have partially tricked me because when i first sat down in the Kart (after he already left :mad:) the drive tire starting bubbling a lubish smelling liquid (maybe a filler so it looked like it held air). It doesn't hold air. I believe this tire may use a tire tube so is it the tub leaking? If so would I only need to buy a new tube?
actual tire in picture is of the adjacent tire, not the drive tire.
colestreasures
Kentucky
You got a good deal at $80 IMHO, the tire probably just needs a new tube just check the inside of the tire real good before you put it in, don't look like the sprocket is even bolted to the wheel or or anything so it's not going to turn with it, I can't tell really but it don't look like it has a hub to bolt to. Not sure but that's what it looks like to me anyway, so can you lift it up and turn the drive wheel and everything turn with it now ?
Cole
colestreasures
Kentucky
Or should I say what's holding the brake drum and sprocket to the drive wheel ? All 3 pieces need to turn as 1 unit to work.
Cole
firemanjim
Just kartin' around....
Houston Texas
There is a double sided hub in there. The wheel is bolted on to one half. The brake and sprocket are bolted on to the other side. I'll post a pic of one if you need me to.
colestreasures
Kentucky
This is very similar to the type hub I posted in my first pic that I'm using on that particular kart, and I use the one like jim posted the link to also , there are several different types the main thing is you have the correct bearing size for your axle and when all together it lines up good and true/straight so the chain or brake won't bind and such .
Cole
NapalmicAcid
Here's a pic of one of mine have more pics if needed.
Cole
Thanks for the pic. My Manco go kart is set up just like your picture but this new Go-Kart is not set up like that. It has not bolts in between the brake rotor and sprocket. Just all connected.
NapalmicAcid
The problem is not the thing turner, all three pieces are connected, I will try to get a picture soon. Just not like most Go-Karts
Hursty
VOX NIHILI
Denver PA
$80.00 that's an awesome score. Around here rusted frames with flat tires an no motors bring 100. Plus
NapalmicAcid
Please do I would like to see how it's setup.
Cole
Here are some pictures, rusty parts but I got my old spares to replace them all. It bolts to the tire base form four small screws with bolts behind the brake drum
NapalmicAcid
got a question for you guys, Whenever i take turns in the Go-Kart (and sometimes just randomly, scary) the go-kart can swerve out of control or in some (most) cases just be hard to turn the wheel, but once you turn it it certainly turns. Tires make a kreeky sound. Could it be overinflated tires? bad tire bearings? I oiled up most of the bolts and connecting areas around the tires and where the wheel turns the axle, but didn't seem to help.
It sounds like it could also be bad steering geometry on the kart. If you take some pics of the steering we can see. Take the pics from abobe the tierods, wheels etc. One pic with the wheels facing forward, and then one each of the wheels all th way to each side
Ahhhhh....you jest kaint drive.....JK!!!!
NapalmicAcid
Here some pics. Also another question for you. I have a Tecumseh OHH60 engine (broken) and checked back at one of my other posts and found the replacement OHV and camshaft i needed, but can't find the gaskets I need. Can someone direct me to it on eBay or such?
I have no idea how that thing turns, the steering geometry is simply all wrong; someone's done a real number on it...
As for the creaking sound, check all the wheel bearings...
