cvt question dinli 50cc engine
malodin
so i pulled the cvt setup out of dinli quad (basically one of those Italian scooter designs) and after looking at it and how the variator works on it i think i can adapt it to fit my 3hp tecumseh motor. i have some questions though as it has splined ramp plate and outer pulley my question does both of these pieces need to be driven or just one? as some of the online variators i see show smooth bore on the inside pulley. if they need to be fixed to the shaft i can make that happen just want some thoughts/opinions on it.
malodin
if you look at the picture of the outer sheeve with the star that is splined i think i could bore the splines out and weld a nut or bolt to it that would thread into the shaft on the tecumseh. then on the ramp plate? that is splined also i could cut a keyway into that and put a c-clip(or shaft collar) on the crankshaft to hold it all assembled
malodin
well i am researching this cvt and i cannot tell if its setup to run between 0-3k rpm or higher some info online says 8k but i dont think so.
Anyone know?
Anyone know?
I was just going to mention this. Most quad and scooter cvt's have an engagement speed that is waaaay too high for a normal industrial engine like the one you want to use
malodin
Landuse,
your probably right...oh well i have a spare clutch setup for my sons eton lightning quad.
