I have a 3hp tecumseh motor i am planning on running in my little powpowwheels project for my son, it has a 5/8" shaft and the jeep is going to be primarily around the lawn/offroad style so i am trying to decide if i should go with a clutch or a torque converter.
i parted out a dinlo quad that i am using most all the parts from. except the motor as it was shot,it had a built in cvt trans but i kept most of the belt drive parts but i dont know if it will be worth using. i have a mill and lathe so i can make adapters to the shaft and what not if its a decent clutch setup, it has SM1 stamped on the V-pulley
i have some space constraints as can be seen in the pic with the engine inside the jeep
You'll need pretty high gearing just to make it move &, being that the driver is only 6, the gearing will need to be higher still, I'm thinking in the vicinity of 16:1 (which would give a top speed of around 12mph), which will require compound gearing; used in conjunction with a centrifugal clutch, much of the setup can be modified or removed as he gains confidence...
