Removing a "ground down" flywheel nut
MatthewD
Senior Member
Northern Ireland (UK)
Hi all,
I recently got a 1960`s 75cc 4 stroke engine. It`s not getting spark and tonight I tried to remove the flywheel, but the flywheel nut is all "ground down", meaning that when you look down on the nut, it`s round.
How can I remove the flywheel nut? Btw you can`t get vise grips in there to remove it.
thebozz
Beaverton, Oregon
I had a similar problem with a Honda GX240. I took an angle grinder and ground sides onto the nut then took an impact wrench to it, then I notices the threads were also messed up on the crankshaft so I took a dremel to it and cleaned up the threads as best as I could. if this approach dosn't work, you could try heating up the nut to make the metal expand.
MatthewD
Senior Member
Got any pics of what your working with ? Have you tried a chisel and tapping on it ?
Cole
No I haven`t, but I don`t think it would work because the nut is quite badly rounded. I`ll get pictures tomorrow.rounded
Well I could though it would be hard to access, as "ML-TOYS" pointed out:
I am guessing the but is in a recessed section as in a hole
oh.....:rolleyes:
I guess then maybe (depending on how badly it is rounded) you could find a sacrificial socket and hammer it onto the nut then attach to a wrench.
I might try that tomorrow. It seems like a good idea.
Thanks for your Help Everyone. It is much appreciated! :thumbsup:
dengieboy
Essex England
stuck nuts !!
hmmmm a tough one if you cannot tap it round with a center punch or small chisel what i would do is find an old socket that with a tap from a hammer goes on to the nut then with a welder weld the socket to the nut from the back then put you ratchet on and undo the heat from the welding should help free the nut from the shaft
There's a tool called a Basin Wrench that'd probably work for you as long as you have an inch or so of room around the outside of the nut. Its a type of pipe wrench that plumbers use for hard to reach fittings.
MatthewD
Senior Member
Right I`m gonna go out now and see if I can remove the nut. I`m gonna hammer a socket onto it and try and get it off that way. I`m just wondering what size of socket I should use. The original size was 9/16
Not going to say it can't work....but those are specifically made to tighten faucet connections to sinks and water lines....brass with not very high torque...already being rounded....It was probably on pretty tight when that happened....
They get tighter the harder you turn then....so...no problem there....but as you can see by the handle....made for hand pressure and not much more.....I'm afraid it'll just break.....
NO WAY!!!!! Exactly where is this nut????
Oh.....yeah....thread size....maybe....a six point 11/16 should be close....originally probably around 3/4.....
