Predator 212 Flywheel
Bosch
Lincoln, NE
I would like to remove the stock flywheel from my predator to install a timing advance key. But I don't own an impact wrench, yet. Is there a reasonably easy way to remove it without an impact wrench, or should I just go get one and be done with it?
An impact wrench is a handy tool to have.......however....you can pull the spark plug and feed a little rope in and it will keep the motor from turning.....
Badot
Ehhh, I'll give that one to you but when I hear TDC I assume ignition.
Half-breeder
"Edit" button removed
IMO... Id take the engine to the nearest auto mechanic, along w/ 2-5$, have him/her zip it off, install the key, n have him/her tighten it back... total of 'maybe' 2-5 mins of work (wish I made an avg of $60hr). 'That' way no oop's/huh's. Plus, when the engine is off... no 'better' time to do alil cleaning/maintenance on it w/ the convenience of no Kart connected to it...
I have done the rope trick a few times....and it works great. Make sure you use a cotton type rope, because you do not want pieces of nylon or hemp stuck in your engine
KartFab
I got some sockets for my impact wrench at harbor freight. They can't easily screw those up. That's my little rule.
I got my impact wrench somewhere else. Harbor freight makes me happy and sad. Happy for little cheap things, and sad for quality tool/equipment producers. I did break down once and got a $10 pneumatic chisel to take out ~6 sq ft of tile from some cement and that was it. The rest of the tools I get are Milwaukee, Dewalt, Makita, and sometimes Rigid. Sorry to hijack, hopefully u can get the flywheel off!
Badot
I have one of their electric impact guns and haven't used it for anything crazy yet but it did manage to take a siezed up (37mm?) nut off a rear axle, so it can't be too bad. Knocks off motorcycle flywheel bolts with no problem.
My point is, using an impact wrench to re-install a flywheel nut a would be a mistake.
Never said it wasn't....now....I rarely use a torque wrench....it's just unnecessary for 90% or more of what I do....I have a "feel" torque wrench.....that let's me know when bolts are properly tightened........
The most accurate way to measure the proper pressure on fasteners is not a torque wrench.....but to measure stretch....and you can actually feel that...and torque....after years of tightening bolts...with and without a torque wrench.....
There are certain bolts that I will use a torque wrench on...like head and rod bolts.....but again.....I don't need it for a flywheel or most bolts.....because I know from experience how hard to turn them......
So........now we come to the impacts......again.... a GOOD mechanic....with an appreciable amount of time with his impact....can "dial it in"..... and really knowing your tool....you can hear the "pinging".....just like you can feel the stretching......so you can get really close.....
So......what does this mean????? Means that a really good mechanic can do it with an impact.....in no time at all......
HOWEVER...... what Russ is saying....and is absolutely right.....is that....in inexperienced hands....a bozo with an impact can ruin a lot of stuff in a hurry......so.....I wasn't so much discounting Russ' advice......but pointing out that....the earlier advice wasn't the greatest.....and the rope is the better way to go.......anyway.....this IS DIY......right???????
Now.....just a quick story to sum this up.....I've had to replace several wheel studs because inexperienced mechanics tightened up lug nuts with impacts......
Do you want to replace a crankshaft......or use a $2 cotton rope?????
