Comet Kart sales sells the Raptor 2/3 rod for $25 . Would this rod be good enough for a flathead with the only mods being removal of the governor and less restrictive intake and exhaust ?
The Raptor rod is good to about 7000 RPM. They are cast, but they are a better casting, and have the dipper casted in to the cap. I've turned a lot of laps with Raptors back in the day!
Thanks guys. I went ahead and ordered the Raptor rod. I've heard you can't get past 5500rpm with the stock valve springs and that's what I'm sticking with. Is a billet flywheel necessary ?
That's about right - the stock springs give up at around 5500 and the stock flywheel is fine at that RPM. You do need to remove the governor gears inside the case to run at that RPM safely.
