Can You Identify This Engine?
only126db
Fat Karter
Just wondering if anyone can identify it just by looking...Honda?
Hey...before you sign me up....it looks like a Honda to me.....doesn't by any stretch of the imagination mean it is.....I think more pics may be in order....or at least more verification....from some other members.....
Half-breeder
"Edit" button removed
White tank, and red cover... "usually" indicates a Honda. A vin# off of it would tell all. But from 'this' distance... "looks" like a GX160 w/ an old or improvised air filter... and is that an electric start module I see ziptied to the side of the seat?
only126db
Fat Karter
I am actually going to look at the machine today. Yes that is electric start, how it is fastened I am not sure since I have not seen her in person yet.
only126db
Fat Karter
I believe its a clone, I looked and Honda says all their serial numbers have 4 or 5 letter prefixes, this does not.
The serial number starts 168f-2d The only reference to 168f I can find is Lifan which is blue.
I dont know....:(
Xtreme Yard Karts
Sweet Home Alabama!
I'm pretty sure that is a Carroll Stream engine (made for them by Lifan). That recoil design(the way the vents look) doesn't look like Honda's. The recoil design and the air filter set-up matches the Carroll Stream engine. They are red and white like Hondas also.
Honda -
Carroll Stream -
Xtreme Yard Karts
Sweet Home Alabama!
As far as I know they are pretty good. Lifan is said to be one of the better clones, and Carroll Stream states on their website: "Made to Carroll Stream Motor Co. Quality Standards By Lifan", so I'd guess they'd be pretty good.
velocity
here
Looks like a chinese (ugh) clone. The lines/holes/designs and whatnot on starter filter ect are not of honda lineage.
if at first you dont succeed get a bigger hammer....
velocity
here
I do know its either lifan or something like chen shing is actually hondas plant in china a lil research may be in order ......out of boredom
only126db
Fat Karter
Well I believe its a Carrol Stream like Extreme posted. However when I contacted C.S. through their site with the serial number and stating I was trying to identify an engine.
They said.... "Please send us a photo of the engine. The serial number doesn't help. I don't think it was from us."
So I replied......."It looks just like the ones on your site, looks like your cs182 & cs190"
Then I received....... "Do you have a question? I don't know whether the engine is ours or not, but I'm not even sure what you're getting at. It may be irrelevant depending on what you need. Please let me know how I can help. Thanks. Dan"
:horse: :roflol:
velocity
here
Ugh smh china support :p :eek: lol. The best thing I can say is get detailed pics of the entire motor and the serial num. Starters and air cleaners can be replaced. But a. Crankcase ect not as easy to swap out
rmm727
Brookville, PA
Not sure why you need to identify it. If its a Honda, it will have Honda and the CC's cast in to the block. If not, its a clone. Might be a 5.5hp (168cc) or a 6.5hp (196cc) or could be other sizes as well but not as likely based on the pic you provided. No need to bother Carrol Stream anymore. If you need to figure out if it is a 5.5 or 6.5 just count the number of large cooling fins on the block before the deck surface (where the head bolts on)2 large fins equals a 6.5------1 equals a 5.5hp.
only126db
Fat Karter
Replacement parts, maintenance....? You cant very well buy just and old part and JB Weld it on, or can you ? :popcorn:
rmm727
Brookville, PA
for the most part....YES. Is there a problem with the engine? Do you even own it yet?
There are some exceptions to this but that is mostly with the Predator models
velocity
here
Ok that a neat idea using the fins like that I usually measure the bore with calipers and get the spec of diff engines till I find a match. Rmm has a point honda has identification cast into the block. And unfortunately even with chinese clones motors may look identical but many use completely diff parts. Add in ones stroke might be a tiny tiny bit longer with just a larger bore to still keep the same cc some might be good with one type of intake Restriction (honda xr stock engine finickiness) while not running at all with one. Tiny change one may use one resistance another something diff. For a few of many examples for the most part. Sometimes you can swap entire. Carbs around....if the bolts and ports match but that's not exactly a given what's the model serial ect numbers? I've got a. Few suppliers I can run it by to see
