engine swap question
kevbo22
Colorado
I have a 150gka-2 150cc mini buggy. It has a GY6 motor in it right now. This particular GY6 is a 1p57qmj and becuase of that P in there, I cant do a big bore. And even if I could, it would cost a ton just to get the 200-232cc BB kit.
While I have had a ton of fun with this current setup, I need more power! This thing weighs 720lbs. I do a lot of off road trails here in Colorado so power is my goal not top end speed.
The complete back end of this mini buggy and engine cage are on with four bolts (very similar to spyder carts arachnid). This makes fabricating a whole new back end very easy.
So here is what I am looking at doing:
1.take the current back end off and weld up a new one.
2. I would like to swap the motor with a 23hp vanguard 630cc or honda equivalent with a torque converter and gear box.
I dont need aggressive top end speed, say 35-40 would be just fine. But I do want a lot of power for the climbs on the mountains.
I would be willing to consider a predator 420cc 13hp as well if it provided the power i am looking for.
So do you think the vanguard would be good or will the predator 420cc 13hp be suitable?
Please do let me know what your thoughts are.
-Kevin
BirdFanatic
Jonesboro Arkansas
I would be willing to consider a honda gx660 13hp as well if it provided the power i am looking for.
So do you think the vanguard would be good or will the honda gx660 13hp be suitable?
-Kevin
Weld a mounting plate to the frame drill the slits wider and longer for multi engines to be able to be put on it beaf up the back and throw a 18hp v twin on it with a tc or a comet 94c like whats on a snowmobile and fl250s.The gy6 only makes 8.6 hp at 7200 rpm or if you want to you can go here and look at all the parts they make for the gy6 http://www.scrappydogscooters.com/125_150cc_Performance.html
720lbs, are you sure about that? That seems like a lot...
At that weight, with a 23hp engine, you'll have a slightly lower power: weight ratio (31lb/hp) than a Ford Fiesta (being 29lb/hp) but transferring that power to the back wheels is what's important...
Contrary to popular belief, it is possible to have too much hp... (or, more to the point, a poor delivery system)
A friend of mine owned a Holden Maloo which he kept working & tuning to a point where his mechanic said "if you do any more you'll be going backwards".
What he meant was, he could extract more power from the engine but, it would be pointless doing so because he couldn't transfer that power to the road surface in a way that it would be "useful"; in gaining power he would actually lose the ability make the car do what it was meant to do...
kevbo22
Colorado
I really have no intention to upgrade the existing GY6 in it. After a CDI, weights, springs etc. etc., I could easily purchase a 13hp. predator engine. And as I said earlier, this particular GY6 cant get a big bore kit for because of that "P".
kevbo22
Colorado
It is. I just looked it up in my owners manual.
kevbo22
Colorado
So right now, the current GY6 is around 8hp with 4.5lb/ft.
The vanguard is 23hp with 33lb/ft
and a predator 13hp is 18.9 lb/ft.
I can pick up a predator from my local HF right now for $270! This engine with slight mods could easily be 18hp and is quadruple the torque.
Would the predator be ok? Give me the power I want, at least it has to be better than the current GY6 yes? I still want to keep a top end speed of like 35-40mph as well
BirdFanatic
Jonesboro Arkansas
Says its 720 ibs http://www.kandiusa.com/product_veh.php?id=13
Id be happy with a gx390 lol even a used one you can make them push out a lot same with the gy6 but for me i find the ohv engines such as the gx390 and predators are much easier to work on .I would find a used predator or honda for less then half the price if your lucky you can find a electric start on cl .Also plz fill out your profile so we can help you better your location can tell us a great deal in the future.
BirdFanatic
Jonesboro Arkansas
Take the governor out put a billet rod and better springs and you have a fun toy plus the 18 hp is huge and weighs about 120 pounds the gx390 weighs about 80 and the mounting plate would be better to find then a 18hp mounting plate .
kevbo22
Colorado
Correct me if im wrong, but is the predator 13hp that I speak of just a knock off of the honda gx390?
So basically what you are saying is it should be pretty good for what im looking to do.
kevbo22
Colorado
Awesome! I think i'll try it just cause I can get one right now for $270! Thanks a lot for the input!
Cam, don't give false hope; some of us get extremely lucky but, in my experience, deals like that are few & far between...
I could be wrong but, I'm not entirely convinced a 13hp engine will give you what you want; yes, a few performance parts will gain a few hp but, it's gonna cost you...
BirdFanatic
Jonesboro Arkansas
The gy6 parts cost a heck of a lot more then the clone parts. just a muffler kit for the gy6 is over 150$
Xtreme Yard Karts
Sweet Home Alabama!
I would think that the 18 lb/ft of torque would make a huge difference in pulling the kart on hills. It also not unrealistic to think that with a header, jet, and air filter that it would pushing 20 lb/ft. That's not too shabby with the correct gearing.
Xtreme Yard Karts
Sweet Home Alabama!
Hogwash! That just means it's time to do suspension work and change tires. :)
I agree though, you get to a point that you pretty much have to make it a race car/vehicle to hook the power.
BTW, your kart does not weigh 720 lbs. They are closer to 450 - 500 lbs. My buddy has one, and he and I have picked it up and put it on a flatbed truck several times.
EDIT: I just looked it up, and the gross shipping weight with crate packaging, etc is 723, but the net weight is 496 lbs.
http://www.dirtcheapmotorsports.com/kandi-150cc-go-kart-kd-150gka-2.html
By now, I would've thought you'd have noticed the Edit button in the lower right corner of your posts; please use it to avoid multiple consecutive posts :)
Xtreme Yard Karts
Sweet Home Alabama!
But how will I ever get my post count up? That's street cred, ya know! ;)
I know about the edit button - I actually edited the post about weight.
In my forum experience, you usually only edit a post a few minutes afterwards because most people don't read a post again after they've already read it. I've missed a lot of edited posts before like that myself.
Of course, this is your house and your rules. I was only trying to help. :)
